Old 09-01-2014, 01:39 PM   #1
My furnace won't light
Hi,
I have a 2014 27RKSS and my furnace won't light. It goes through the motions of trying to start but no luck. It does the clicking two or three times.
We just spent 3 nights and 4 days and managed to get it to light twice but that's it. This morning it lit and warmed up the trailer but would not light again.
I did the purge exercise as is in the manual with no success. The fridge, stove and hot water all work fine.
I have not called my dealer yet as it's a holiday. What could be the problem? Suggestions welcome.
2014 Salem 27RKSS
Burgeogull is offline   Reply With Quote
Old 09-01-2014, 01:51 PM   #2
New to Forest River
Roving Ron's Avatar
I had the same issue with a previous PUP. Check for spider webs in the air tube that leads to the propane burner.
Ron
Grey Nomads, Ron and Sue
Grey Nomads:l Ron & Sue
Roving Ron is offline   Reply With Quote
Old 09-01-2014, 02:14 PM   #3
ourflat's Avatar
Sometimes there is just too much air in the LP supply lines. I usually fire up the stove and let it run for 5 minutes to ensure the LP lines are purged. You'll be surprised how much air in the LP supply lines there is....
Frank
2016 Days Camping so Far: 24
2013 3051S Forester
2013 Elantra GT (Toad)
WashU EMBA "39
ourflat is offline   Reply With Quote
Old 09-01-2014, 02:20 PM   #4
Well, my fridge is always running. But when it lit this morning it was after the hot water was on....I dunno.
2014 Salem 27RKSS
Old 09-03-2014, 08:18 AM   #5
Well I figured out my problem. Low Batteries!! Apparently when batteries are low, 12.5 or less as far as I can figure, the furnace will not light. Works fine today.
2014 Salem 27RKSS
Old 10-01-2014, 08:52 PM   #6
Well apparently it wasn't the battery low at all. It failed again. Turned out to be the circuit board on the furnace.
2014 Salem 27RKSS
Old 10-02-2014, 09:15 AM   #7
Low batteries are still a failure point. The low voltage keeps the fan from moving fast enough to trigger the sail switch.
techntrek is offline   Reply With Quote
Old 10-02-2014, 09:43 AM   #8
Iwannacamp's Avatar
Prolly wont help.... My furnace was acting weird... I pulled the furnace( not super easy)... did the "wiggle test" (plug and unplug) connections... retested partially unassembled... worked fine. Reinstalled... worked a few times... went camping...no work. Replaced circuit board... no trouble since
furnace, light
