Old 05-20-2016, 02:33 PM   #1
Need a solution for hot pantry
We have a hemisphere 302FK, love the front kitchen but there seems to be no insulation on the front fiberglass cap which leads to a very hot pantry in the summer especially when sitting in the sun. Earlier this spring even with very mild temps we ended up with melted hershey bars. Anyone have ideas on how we could insulate it?
Bear fans is offline   Reply With Quote
Old 05-20-2016, 02:37 PM   #2
Georgia Frog Rally 2017
aceinspp's Avatar
We have a similar problem but are door is located on the side wall along side of frig. We have thought about adding or making a louvered door and maybe add a small batt operated fan to exit the warm air. You might be able to do the same. This is in progress now. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days booked for 2016--60 missed by 2
Days camped in 2016 58
Days booked so far in 2017 37
Old 05-23-2016, 10:12 PM   #3
Keep me posted on your mod and how it works out. Ive thought about getting some kind of insulating blanket and attatch it to the pantry wall. Our pantry is right up front the fiberglass cap absorbs heat transfers it into the pantry and cabinets in a the front of the camper.
Old 05-29-2016, 02:37 PM   #4
Cut in a vent, use a computer power supply fan wired to a manual RV thermostat mounted in the pantry.
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 05-29-2016, 03:17 PM   #5
WolfWhistle's Avatar
You have the optional heated pantry option. Just throw the switch to "summer" and you should be good to go.
I personally wouldn't take a chance with my Hershey bars... keep them in the fridge.
Just having fun.
Seriously, the walls are very slightly insulated and with the cabinet closed, it builds up heat... mine too.
I bet you could add some kind of decent looking vents to the top of the pantry door... I assume the bottom has a large gap towards the floor... and what I would do (or also do), is to cover the back walls of any or all cabinets with Reflectix insulation. Cut to fit and staple up. I used it on my floors and cover windows. It blocks nearly all the light and most of the heat. If you aren't sure what this is, here's the product offered by Lowes. It comes in various widths and lengths.
WW
Shop Reflectix 24-in x 25-ft Reflective Roll Insulation at Lowes.com
XLR Hyperlite 29HFS
Ram 2500 6.7L CTD
Triumph Thunderbird
A Modder's work is never done!
Old 05-29-2016, 03:23 PM   #6
Good idea I have considered some sort of insulating blakent on the walls. You can touch the walls and feel the heat, maybe a combination of thin insulation and venting might work.
03Ram2500
16Hemisphere302FK
Old 08-04-2016, 04:30 PM   #7
Road Dog's Avatar
Similar issue with our pantry. I think it may be warm because of the refrigerator.
Any update/results regarding the fan install?
Thanks!
_________________________
2017 Rockwood Ultra V
2015 Ford Expedition Limited
Road Dog is offline   Reply With Quote
