Old 03-25-2016, 12:10 PM   #11
caper's Avatar
If you know where the pump is located it will be behind a false panel or door. There should be a valve at the pump this will be the valve and hose to add antifreeze to the unit. This should have been shown to you during your PDI walk through.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 03-25-2016, 12:39 PM   #12
RudysWorld's Avatar
My process for starting up is open pressure relief valve on water heater until water flows out and then shut. Then go to each facet and run hot and cold sides until each run smooth. This clears lines of air and everything runs smooth. This assumes pump is in the normal operating position not antifreeze fill position. Good Luck!
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 03-25-2016, 03:29 PM   #13
Tfort's Avatar
There should be 2 valves in the front drivers side compartment next to your water connections. One is a small white valve and the other is the red hot water bypass valve. Make sure the white valve is on to pull water from the fresh water tank. Click image for larger version
Name:	ImageUploadedByForest River Forums1458937739.529510.jpg
2000 F250 CC 4x4 7.3L diesel
15 Salem Hemisphere Lite356QB
Tfort is offline   Reply With Quote
Old 03-26-2016, 05:20 AM   #14
nomad297's Avatar
Originally Posted by camplight View Post
??? - Bruce - I am not following.
I guess i could have used a better word than "drastic." All I was meaning to say was for something that seems like it's going to take extreme measures to repair, it really is a simple fix.
Bruce
Old 03-26-2016, 05:35 AM   #15
Chief tinkerer
Gidyupgo's Avatar
G'mornin camplight. Curious, did you figger it out?
Gidyupgo is offline   Reply With Quote
Old 03-26-2016, 10:01 AM   #16
camplight's Avatar
Good morning all. Thank you for the comments pictures and help. First thing yesterday morning, I dug into this. Yes, I got it figured out. Here is what I learned from my setup.
Found the pump and the vacuum side does not have a valve. Vacuum side has a line to pull in antifreeze and a line to draw from the tank all in a "T" connection. The cap plug needs to be in the line that you suck up antifreeze from. I have a direct fill line to fill fresh tank, no valve there either. There is however the white valve that need to be open to draw water from the tank (not labeled).
It was all much clearer once I could see the pump and lines. This is my first 5er and much different than my previous TT.
Thanks for the help! Happy camping!
camplight is offline   Reply With Quote
Old 03-26-2016, 10:04 AM   #17
camplight's Avatar
Originally Posted by Tfort View Post
There should be 2 valves in the front drivers side compartment next to your water connections. One is a small white valve and the other is the red hot water bypass valve. Make sure the white valve is on to pull water from the fresh water tank. Attachment 102816
I did not know what the white valve was for until I took the panel off to get to the pump. Thank you for the picture. I also learned I needed to cap off the antifreeze suction line.
