Old 09-20-2016, 07:01 AM   #1
Need some help with stove burner
This morning got up to cook breakfast and turned on burner and only got it to light half the burner. Any suggestions to whats wrong ?
wildtigger2 is offline   Reply With Quote
Old 09-20-2016, 07:15 AM   #2
Propane tank(s) empty?
Frozen regulator?
Stuck check valve in the feed line?
Kinked line to to stove? (if in slide)
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
Nights Camped: '15 = 22'16 = 46
Old 09-20-2016, 08:10 AM   #3
jeff
jeff64's Avatar
dirt! Try blowing it out with compressed air. If you don't have that , go to Staples and by a can of compressed air like you'd use for camera lenses and electronic stuff. I am assuming one burner not showing flame all the way around. Your description leaves something to be desired from my understanding
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 09-20-2016, 09:38 AM   #4
Head Rambler
Do the other burners work correctly?
If so, it's probably a clogged orifice for that burner. If not, it's either some of the above or a failing regulator. You can check the pressure at the stove. It should be 11" WC.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 09-20-2016, 08:54 PM   #5
It was two of them. Oil got spilled on them. I cleaned them up. Its working now. Sorry for the poor description. On our 3d day of traveling from deep south texas to washington state. One more day
Old 09-21-2016, 09:07 AM   #6
Head Rambler
Thanks for letting us know that you got it figured out and fixed.
Gotta go campin!
burner
