Old 10-29-2010, 08:44 AM   #11
If you can, I would suggest camping in it in your backyard or driveway first, and trying all of the systems and appliances, to become familiar with their operation, as well as to identify any abnormalities. That way, there are no surprizes when you do take it 50 miles from home to a campsite in the middle of the woods. Randy
Old 10-29-2010, 09:19 AM   #12
carl.net
That sounds like very good advice. My neighborhood does not allow trailers but there is a camp ground two miles from where I am storing the TT and 1 mile from my house.
carl.net is offline   Reply With Quote
Old 12-05-2010, 09:02 AM   #13
carl.net
1 Month in punch list
One month from purchase punch list of things I have done.
- Tires and Breaks
1. Replaced original China bomb Bias play tires with new China bomb radials. I figured that since most if not all tires are now made in china I should at least have new ones that have been balanced.
2. Adjusted breaks to spec.
3. Install Bearing buddies on all four wheels
- LP Systems
1. Replaced leaking 30# LP tanks.
2. Replaced leaking LP pigtails.
- Water and sewer
1. Installed ball valves on the low point water drains.
2. Replace Valtura T1015 sewer drain pipe
- Electrical
1. Replace 7 pin trailer light pigtail.
2. Rewire 7 pin pigtail junction box so that break lights and turn lights actually work.
3. Install new 135 AH deep cycle battery.
4. Install battery shutoff switch.
5. New battery box.
6. Solar trickle charger for battery.
7. Replace breakaway switch
8. Replace battery in smoke and CO2 detectors
- Kitchen and bath
1. Have recall serviced on Dometic refrigerator.
2. Install new anode in water heater.
3. Install paper towel holder in kitchen
4. Install hand rag towel at bathroom sink.
5. Replace bathroom fan
6. Install new showerhead and hose.
- Other
1. Install and set up weight distributing anti sway hitch.
2. Modify queen bed platform to take a full size queen mattress
3. Fix three leaks in roof using eturnabond tape.
4. Replace door locks with new ones that are keyed alike.
5. Clean and paint towing chain
6. Clean and paint battery box
7. Bend steps back to spec
Old 12-05-2010, 09:22 AM   #14
MtnGuy's Avatar
Wow. Did you have enough time to eat and sleep in between all of that ??
Old 12-05-2010, 09:57 AM   #15
carl.net
Not really. I had about 3 weeks to get it all done in and still do my day job... Grin.
Old 12-05-2010, 10:42 AM   #16
Herk7769's Avatar
Wow Carl. Good job. Now get out there and enjoy the great outdoors!
HAM CALLSIGN - KC3FFW
Old 12-27-2010, 10:18 PM   #17
xf021209's Avatar
Doing the same thing, completely customizing my FEMA TT. Just ripped out the very small bathroom in the back and bunk beds have also been removed. New bathroom will be full width of the back of the trailer. Already have clean, gray, and black water tanks and more. While demoing the bathroom I found the workmanship to be pretty poor. That makes sense for as fast as these TT's were being assembled, but the construction is VERY solid. It took me over two hours to get the bathroom disassembled and all parts removed. Looking forward to getting the remodel done and using the trailer next year. Have fun Carl.
xf021209 is offline   Reply With Quote
Old 12-27-2010, 10:24 PM   #18
carl.net
I would be very interested to see what you have designed and are building!!
- 06 Salem LE 28BHS (axles flipped), Boliy Pro3600ES Generator
Dodge Dakota 4.7l HO (260hp/310torq), 131 in wheel base
3.92 gears with towing pkg, Reese dual cam sway control
Tekonsha P3 break controller
- 36 ft Monterey cabin cruiser, Stainless blender
Two 4.7 GXi I/O (2 x 320hp = 640hp)
Old 12-27-2010, 10:59 PM   #19
xf021209's Avatar
Your welcome to check out what I'm doing and my progress at the following link. Let me know if you are unable to see the pictures.
Todd
My FEMA Travel Trailer Project | Facebook
I'm enjoying the work. Hope to have the inner walls, linoleum, and carpet pulled next weekend. Plus I will have to remodel the closet that is outside the bathroom. I'm going to move the bathroom wall forward just past the rear window. This'll mean I have to move the power inverter too, but that isn't that difficult. FR left enough wire length so that I should be able to move it about a foot forward to be in front of the new bathroom wall. More to come.
Old 12-28-2010, 07:36 AM   #20
carl.net
Very interesting and thank you for posting a link to the pictures. Yours is a park model so it is set up differently on the inside. Your foldout is where my kitchen is and where your kitchen is located is where my foldout is located. Also my bath tub runs along the back of the trailer. I also noticed you have your hot and cold pipes in red and blue flex whereas mine are all white flex.
When you are done please post again as I am excited to see the finished bathroom. Will your new design include a back bunk?
salem
