Old 03-22-2011, 06:09 PM   #1
New 26TBUD, thinking of mounting a TV... Ideas?
Recently purchased a 26TBUD and loving it. Thinking about installing a 22 or 26" LCD TV in the spinning entertainment center thing.
Any suggestions? Or installed pics?
- From what I read it's a good idea to take the TV down during towing.
- The backing should be strong enough to attach the TV mount with some bolts and washer. No need to do additional backing or support. Correct?
- Anyone do the mirror install on the other side?
I'm not normally afraid of installing a TV but drilling into that wood on my virgin 26TBUD is intimidating.
Thanks, for any suggestions.
brianb is offline   Reply With Quote
Old 03-22-2011, 06:19 PM   #2
dretired's Avatar
tv mount
I also am debating on mounting a tv or not. the area that i have is very flimsy to do either a base or wall mount . i can see some fabricating and re-enforcing taking place. and im still not sure about the ride going on back there..
dretired is offline   Reply With Quote
Old 03-23-2011, 03:45 PM   #3
I just bought a 26tbud in January... mounted a 26" with no problems. The TV case is double walled.
sleblanc63 is offline   Reply With Quote
Old 03-23-2011, 06:56 PM   #4
Ehlendt's Avatar
Send a message via Skype™ to Ehlendt
He's right. The back wall of the unit is plenty thick. My mounting bracket is held in place by 4 screws; no bolts here. Depending on my mood when tearing down at camp dictates if I take the tv down or leave it up during the haul home. Hasn't budged a bit when I've been in a bad mood.
Just make sure you use screws that are shorter than the depth of the mounting wall and you'll be fine.
I have the 26TBUD and love the pivoting tv option. Only need one tv. Otherwise the DW would need a 2nd in the "bedroom".
Goog luck!
John & Johnna
2005 Tahoe Z71
2010 Salem 26TBUD
Reese WD Hitch
"Get busy living.....or get busy dying."
Ehlendt is offline   Reply With Quote
Old 03-25-2011, 01:17 PM   #5
Goog luck!
Thanks for the info! I was tapping on the backing and it sounded like it was double walled. So for mounting did you just use 1/2" screws or is that too long?
Old 03-25-2011, 02:25 PM   #6
Captain of Industry
Call your dealer to verify the depth of screws you should use. They will know right away... Mine should be exactly the same as yours and I was told to use 3/4" lag screws, which I did. I bought an LCD bracket at Wal-Mart for ~$25 and it was easy to install. Bought the 26" LCD tv at Costco when it was on closeout. I've left mine up since I installed it. It gets checked whenever the camper gets moved and it still seems very solid.
2013 Ram 2500 HEMI 3.73
2011 Puma 259RBSS fifth wheel
jdudd is offline   Reply With Quote
Old 03-28-2011, 07:51 PM   #7
Ehlendt's Avatar
I just used a tape measure. Pivot the tv nook so you are looking at the side. Measure the depth on the outside. Stick the tape measure on the inside and measure the depth from the back wall to the front. Subtract. You now have the depth of the mounting wall. Go a little shorter than this when selecting your screw length! Sorry, I can't remember the measurement.
John & Johnna
2005 Tahoe Z71
2010 Salem 26TBUD
Reese WD Hitch
Old 04-05-2011, 08:58 AM   #8
one day at a time
Idle_Idylist's Avatar
Well we picked up our Tbud a few weeks ago and picked up a tv yesterday. I guess I'm going to try this today. I agree it doesn't seem strong enough but you guys have convinced me it will work. I bought a 26" Vizio led that only weighs 13#. Here goes nothing!
Idle_Idylist is offline   Reply With Quote
Old 04-05-2011, 06:33 PM   #9
Please post some before and after pics, and any lessons learned. (If you don't mind.) I hope to install one in the fall, probably same TV - 26" vizio or similar brand w/ a flush mount. But right now I'm spending a small fortune on all the odd's and end's for a new camper.
Good luck with the install!
Old 04-05-2011, 09:49 PM   #10
I'm so glad you asked this question. I also just got a new 26TBUD about a month ago, and I'm dying to get a TV in there. I'm wondering if you have to get one of the "flush mounts" so that the TV doesn't stick out too far to interfere with the swivel.
I also am interested in the mirror mount - that's a good idea.
Kara in Memphis, TN
plus a 6 year old son, twin 2 year old daughters, and a husband
March 2011 - bought our first TT - 2011 26TBUD
Nights camped so far in 2011 - 2
karaintn is offline   Reply With Quote
Old 04-05-2011, 10:07 PM   #11
Yeah, I've seen the mirror setup at RV shows. Looks pretty good, I wouldn't mind doing that down the road.
For the TV I was also thinking a flush/low mount would be better... I'm just going with one of the low profile ones on Amazon for $15-20. No tilt or anything, just a simple flush wall mount.
My only concern with picking "any old" mount would be it's durability in an RV setup. I figure I can work around this in two ways - mount the TV only when setup (not ideal) or install some mechanism so the TV can't bounce out during transport. I guess I could jam a block of soft foam above the TV during towing or install a screw from above locking the TV in the wall mount. I've read a few horror stories of TV's bouncing out of the bracket during travel and finding them on the floor.
It's weird installing a TV isn't covered in the manual... But I guess that's a dealer markup...
Old 04-05-2011, 10:16 PM   #12
I've never mounted a TV before - is it easy to just take it off the mount and then put it back in? Does it just slide in and out? If it involves tools I know we wouldn't want to do that. We typically take short (2 or 3 day) trips and it just wouldn't be worth it.
Kara in Memphis, TN
Old 04-06-2011, 07:24 AM   #13
I wouldn't worry about the turn... I bought a TV with abuilt in DVD player wich adds to the depth of the TV. I mounted it on a mount that allows for up and down angle adjustment (so it veiws better in the bed) and that added to depth. Your depth concern will be closing the bedroom pocket doors over the face of the TV. Mine still fits fine. I also recently told on another post of the problem with the integral cable jack in the wall blocking Direct TV if you use the outside cable jack....
Direct TV cable problem solved
Old 04-06-2011, 08:52 AM   #14
I mounted a 26 vizio no problem. I made the dealer upgrade the concertone before I would buy it. . Works fine.
Daniel
firedaniel is offline   Reply With Quote
Old 04-08-2011, 04:57 PM   #15
Owner - RVtronics
Bob Fields's Avatar
Send a message via AIM to Bob Fields Send a message via Skype™ to Bob Fields
Daniel
And what did they upgrade to?
Bob Fields
bob@rvtronics.com
www.rvtronics.com
(781) 281-9440
Bob Fields is offline   Reply With Quote
Old 04-08-2011, 09:28 PM   #16
a concertone with the DVD player in it. Told them I would buy it if they put the DVD model in it. They did... But didnt wire it correct go figure. But it was a easy fix.
Daniel
26tbud
