Old 03-30-2015, 01:07 PM   #1
rtidwell's Avatar
New Owner- Cruise Lite 195BH- and some questions
Hello-
I'm new to the forum, and new to this camper. We've had a couple other campers- but this is our first new one.
The unit we bought is clearly a "starter camper", based on the price and what is in it.
It did not come with a pre-installed stereo, and I don't remember being offered the option. Does anyone know if these trailers are pre-wired for a sound system?
Thanks, in advance.
Russ Tidwell
Garden City KS
2015 Salem Cruise Lite 195BH
rtidwell is offline   Reply With Quote
Old 03-30-2015, 07:14 PM   #2
jawga's Avatar
ours wasn't. we enjoy ours and also bought ours due to price, but also that means less to break and go wrong too.
jawga is offline   Reply With Quote
Old 03-30-2015, 07:26 PM   #3
Wa11y757's Avatar
X2 on the not being prewired. We also love our 195, although the wife is ready to upgrade. Watch your loading, somehow I'm at 625 tounge weight and I have hardly nothing in it. It's just the two of us!. Anyway congrats. P.s. hello jawga!
Wa11y757 is offline   Reply With Quote
Old 03-30-2015, 07:35 PM   #4
jawga's Avatar
hey wally, yeah that tounge weight does seem high, we have talked about going bigger also but i really dont want a slide and I really like how short the camper is and dont really want longer
Old 03-31-2015, 12:23 PM   #5
2016 Avenger 26BH
we have a 2013 that came with radio installed. maybe no radio is F.R way of keeping price "in line"? Marketing ploy smaller packages same price rather than same package higher price?
Cleon is offline   Reply With Quote
Old 03-31-2015, 12:26 PM   #6
TURBS's Avatar
Personally you'd be better off installing what you want.
IMO the factory radio and or radio dvd combo is cheap and at the lowest end of quality.
TURBS
08 duramax tuned n modded, 32bhok Sabre
Old 03-31-2015, 06:27 PM   #7
Wa11y757's Avatar
I think people would be surprised if they got an actual tounge weight. I have a blue top, full gas bottle, electric tounge jack and 2 wd hitch brackets. Sticker says 400lb tounge, bs!....I'm over 600
2014 Wildwood X-lite 195bh......Happy camping.
Old 04-04-2015, 06:48 PM   #8
TN_Cruise_Lite's Avatar
I added a stereo to ours today, very easy. Like the fact that I can run the sound for our TV through it too.
2018 Coleman Light 1805RB
2010 Chevy Silverado 4x4
2013 Salem Cruise Lite 195BH (traded)
TN_Cruise_Lite is offline   Reply With Quote
Old 04-14-2015, 02:54 PM   #9
rtidwell's Avatar
TN_Cruise_Lite- is that in the little cabinet next to the fridge? I like that a lot!
Old 04-14-2015, 02:58 PM   #10
rtidwell's Avatar
Out of curiosity- where is everyone mounting the fm antennae?
Old 04-20-2015, 08:34 PM   #11
Golfnbike13's Avatar
Love that install, never thought of that spot. Where did you pull power from? I'm assuming your TV is mounted above that counter beside the microwave, where did you run the audio cord to TV?
TT- '21 Spirit XTR 2146BHX
TV- '19 Nissan Titan XD Cummins Diesel 5.0
Golfnbike13 is offline   Reply With Quote
Old 04-29-2015, 10:44 PM   #12
Power comes from the TV antenna power supply. Audio plugs in the headphone jack on the TV to the input on the radio. I can actually hear the TV with the A/C on now.
Old 04-30-2015, 10:27 AM   #13
Do you need a car audio install kit to hold the receiver? I've done several radio install in car but never camper. Just wondering what supports the receiver?
Old 04-30-2015, 12:07 PM   #14
That section of the cabinet is hollow so I drilled 3 evenly spaced holes on the inside and filled the cavity with low expanding foam. Made it super stiff. Then I just cut the hole to fit the radio and used the supplied hardware.
Old 04-30-2015, 12:25 PM   #15
Smart thinking. I want to install mine in this corner panel by end of bed, but those seem like very flimsy panels. Any suggestions on installing there?
Name:	ImageUploadedByForest River Forums1430414709.018045.jpg
Old 04-30-2015, 01:15 PM   #16
Attachment 75716
I considered the same thing myself since a 12v power source is nearby at the light. I thought about using 3/4" plywood glued on from the back side to stiffen the panel. The reason I chose where I did was acoustics for the TV. I wanted the speakers pointed directly at me since our A/C makes so much noise and my years have rendered me with sub-par hearing.
Old 06-03-2015, 12:11 PM   #17
We are enjoying our 195BH too. It's a strip down version for sure; less gadgets means less things to go wrong. Only thing i have added was a TV and a cable box outlet for it. Love the radio system here. Going to have to study you picture and consider putting one in myself.
We normally use our iPhone/iTouch to play sounds, i was thinking of getting some sort of speakers that are bluetooth and somehow make a permanent place for it in the cabin beside putting in the radio and speaker. But good point about running the tv output sound to those speakers.
tomngo8 is offline   Reply With Quote
Old 08-13-2015, 12:30 AM   #18
rtidwell's Avatar
Stereo Installed
Finished up the install of the stereo and 2 speakers tonight. I went with the front cabinet for the install. I am considering putting a jack in for the "rear" speakers, so that we can plug something in outside.
That'll have to wait until sometime later when I have more time.
I think it turned out pretty well!
Russ Tidwell
Garden City KS
Salem, Cruise Lite 195BH
ID:	85491   Click image for larger version
ID:	85492   Click image for larger version
Old 08-13-2015, 05:55 AM   #19
Russ Tidwell
Garden City KS
Did you use anything inside the cabinets to support the radio and speakers or just screw into the thin panels?
Old 08-13-2015, 06:29 AM   #20
2016 Avenger 26BH
In our 2013 195bh the factory radio is above the bed on the end closest to the door. I expect if they are prewired that is where the wires will end up?
