Old 02-22-2012, 07:24 PM   #11
DougP47's Avatar
I hope to try out the generators this weekend. Hope the weather holds out a little longer. I would like to put a small load on generators till I get them broke in.
DougP47 is offline   Reply With Quote
Old 02-22-2012, 07:41 PM   #12
Earth Station's Avatar
all I can say is beautiful!!! and I want my new FW so that camping season can start!!!
Felicia & Jeff - Missouri
2013 Columbus - 320 RS 2012 F350 CC DRW - 6.7L PSD
2012 Camping 59 DAYS; 2013 50 DAYS; 2014 WAITING
Earth Station is offline   Reply With Quote
Old 06-11-2012, 12:02 PM   #13
Whatcha towing it with?
Steve
13 days reserved in 2012 so far!!
TRAVLINOHIO is offline   Reply With Quote
Old 06-11-2012, 07:32 PM   #14
DougP47's Avatar
Ram 5.7 HEMI
Old 06-11-2012, 07:50 PM   #15
Malco's Avatar
We tow ours with a Hemi as well.
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
1968 Pontiac Le Mans
Malco is offline   Reply With Quote
Old 08-17-2012, 08:00 PM   #16
DougP47's Avatar
Originally Posted by Malco View Post
DougP47 We have a Salem KQBSS and love it.It has the chocolate interior.The only trouble we have had so far was a small issue with the fridge fan not turning off and the bunk room pocket door popping off one slide.Hope you have many enjoyable trips with it.Happy camping.
Malco
We had a few small thinks so far this year.
The hot water went out at first try replaced the heating element. Good to go.
The divider for the cough/bench top rail popped off from the wall side. I tried to nail it back but, the next outing it popped up again. Where the vinyl cap screws screwed in to the frame had split. The wood was pretty soft, so I replaced that and all is well with that.
Went on an outing over the 4th July about 104 F. ouch I will never do that again. My gems parallel set up stop working so I had to run them one at a time. It worked for a little while. By the end of the 2nd day we was heading home both gens blow up with only 18 hours on them. They manufacture replaced them about 1 month later. the gens are working fine for now
Dougp47
Old 08-21-2012, 11:09 PM   #17
Congrats on your purchase. I highly recommend the Equalizer sway control hitch. Every spring we camp close to home. This way you can go get/buy anything that you forgot to pack. Also, make a check list of things that you need to pack or bring camping with you.
2014 Salem 31' KQBTS TT
SOLD - 2011 Salem 30' QBSS TT
2006 Ford F-350, 6.0 PSD, 4x4, SRW, crew cab, short box
Equalizer hitch 14,000 lbs - weight distribution with sway control, 16" Raceline 870 aluminum wheels, Michelin LTX M/S tires LT225/75R16E
SnoSheriff is offline   Reply With Quote
Old 08-21-2012, 11:35 PM   #18
Taranwanderer's Avatar
Welcome to the family! I second the recommendation on the Equalizer--excellent piece of engineering that is super easy to use once it's installed and set up. Good luck with it!
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 08-22-2012, 10:29 PM   #19
DougP47's Avatar
I took the gens for a ride on July 4th weekend. It was 104 at the camp site, can you say HOT. What was I thinking? The gens would not work on the parallel no voltage. I ran the tt on one and everything work till I switched to the other one and that one would shut down switch back to the other one and by the end of the day it had seized up. Took them back and got 2 new one and the parallel port works just fine. What a weekend
Old 08-22-2012, 10:56 PM   #20
I'm assuming gens=generators... Why do you have 2 generators? Why not just have 1 big one?
