Old 03-23-2013, 11:13 AM   #61
DougP47's Avatar
Originally Posted by grimesb View Post
Anyone out there with a 30KQBSS... Looking to de-winterize mine. Dealer says there are 3 valves I need to "flip"... 2 located under the sink and 1 on the water heater.... Can't find any ??
Any pics or advice would be appreciated.
Thanks!
One by the outdoor kitchen
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
DougP47 is offline   Reply With Quote
Old 03-23-2013, 11:15 AM   #62
DougP47's Avatar
One between the wheel wells. Same side
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
Old 03-23-2013, 11:19 AM   #63
DougP47's Avatar
Heater access mod. Plastic latch broke, installed finder nut ans know 8/32 thread. No problems now. I'm also going to move electric switch inside the control panel with the slide control and tank sensors.
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
Old 03-23-2013, 11:21 AM   #64
DougP47's Avatar
Remove the anode rod for heater drain.
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
Old 03-23-2013, 11:24 AM   #65
Bearcat55's Avatar
Thanks!
There is a false wall in the cabinet below the sink. All 3 valves are behind it. It's only held in by two screws that go into the floor. Remove the closest screw and just loosen to back one. This will allow you to slide the panel open and reach the valves. It's definitely tight quarters but you can manage.
2012 Salem 30KQBSS
2010 F150 S-Crew 4x4 5.4L
Bearcat55 is offline   Reply With Quote
Old 03-23-2013, 11:36 AM   #66
DougP47's Avatar
I guess I miss under stood the question. If you need pic's let me know. I changed my square heads out to stud and wing nuts. Easy access now.
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
Old 03-23-2013, 11:42 AM   #67
Thanks Bearcat
First time de-winterizing and my dealer is none to helpful (gets a little agitated with newbies)
I've never used my fresh water tank but apparently I need to fill it to flush the system? If so I'll have to take a separate hose to the campground won't I? Sorry for all the questions.
Any help is appreciated.
Grimes!!2012 Salem 30KQBSS
2013 Ford Expedition
2006 Land Rover LR3
1972 Kim (wife)
1999 Jack (son)
2009 Vic (wheaten)
grimesb is offline   Reply With Quote
