Old 05-12-2015, 01:20 PM   #1
New to fifth wheels
Hi I have a 2500hd Chevy with 8.1 liter gas motor,Alison trans 4x4 8ft box. Considering hemisphere 286 RL .will I need a sliding hitch ? Any box to camper issues( clearance) also anyone have comments on this model. Thanks
rustynut7 is offline   Reply With Quote
Old 05-12-2015, 01:23 PM   #2
Long beds do not need a slider hitch.
What is this intended fivers GVWR? 2500 series trucks dont normally have enough sufficient weight capacity to handle more than about 10,000 GVWR fiver without becoming overloaded.
donniedu is offline   Reply With Quote
Old 05-12-2015, 01:39 PM   #3
iowasparrow's Avatar
I have a similar model and I pull it with a short box, no slider and no issues. I have an Anderson ultimate hitch. That may or may not set it back farther than a 5th wheel plate.
Pretty sure with that trailer I could use a standard plate and still be fine. Forest River did a nice job sculpting the front cap to let you turn sharp.
iowasparrow is offline   Reply With Quote
Old 05-12-2015, 01:41 PM   #4
Jim34RL's Avatar
That funny, Ram says that the 2014 and 2015 diesel with an automatic transmission equipped 2500 can tow up to a 17,000 LB trailer. They must be wrong!!!
I do not really like blanket statements they are usually incorrect.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
Old 05-12-2015, 01:43 PM   #5
Oakman's Avatar
As donniedu said, no you don't need a slider hitch.
The Hemisphere is a nice looking fifth wheel. The only thing I don't like about the 286RL is the small holding tanks.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is online now   Reply With Quote
Old 05-12-2015, 01:48 PM   #6
It may be able to "pull" the weight just fine but the TV may not be able to handle the payload weight of the pin.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2017- 16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 05-12-2015, 01:49 PM   #7
The key word there is "TRAILER" It says nothing about a fifth wheel!
A typical TT will place approx 12% of its total weight on the hitch, where a typical fifth wheel places approx 20-25% of its total weight directly over the rear axle. So, using your example, a 17K fiver would place 3400 pounds directly on the rear axle. Meaning at minimum it would need tires capable of handling 3625 pounds each. 3600 pounds empty plus 3400 pounds plus 250 pounds of hitch equals 7250 pounds directly on the rear tires.
Old 05-12-2015, 01:49 PM   #8
jevanb's Avatar
well, I would bet you that is a pretty good statement but the weight stated is a little low 13k would be my limit as my 2500HD is maxed out with a 12.5K trailer and I am all ready overweight by 400lbs. Yes the newer trucks have a higher rating but his truck is a 01-05 year
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 05-12-2015, 02:00 PM   #9
Oakman's Avatar
Oh good grief not another weight police thread. The model the OP is taking about has a UVW of just 8440 and pin weight of 1640. His 2500 Chevy with the 8.1 liter engine will handle that fifth wheel just fine. How about adding some constructive comments about the model he is thinking about buying.
Bob and Joyce
ATU Local 788
Old 05-12-2015, 02:11 PM   #10
Manufacturers always understate the weight they can really carry. Probably legal department telling them that. I have a smaller truck and a bigger Hemisphere. While I wouldn't take it on a several-hundred mile trip; it works fine for local camping, I just take it easy and don't use overdrive. The hemisphere is really nice, I actually went from a Class A diesel pusher to this if that tells you anything. The Class A was nice but the hemisphere has a really nice layout as you probably already know. It's very kid friendly if you have kids. Lots of play area and the steps go real low so they can climb in and out.
fifth wheel, wheel
