Old 08-02-2015, 10:26 PM   #61
Tom48's Avatar
Let the pressure off by lowering the front. Look for fuse, circuit breaker or otherwise be sure that corner is getting current. Borrow that crank you need from someone else in the park.
Tom48 is offline   Reply With Quote
Old 08-02-2015, 10:39 PM   #62
Evereddie's Avatar
Originally Posted by wbdavey View Post
WACIPI - I'm going to respectfully disagree with almost all the advice you've been given so far. If your trailer is going to sit in one spot for 3 years, take the wheels off and lower it closer to the ground. IMO, as long as the trailer is supported by rubber tires and flexible springs and it's a couple of feet off the ground.... it's going to shake and wobble like crazy. I suggest finding a local RV tech or a company that moves double wide trailers through the park office. Have that guy put the large (2' X 2') heavy duty plastic footers down at the front, back, in front of and behind the axles like they use all over Florida to block up double wide trailers. Then lower the trailer onto cinder blocks and hardwood cribbing until it's low and level all around. All this work should not cost more than $500.
I agreed with this post earlier but have a burning question. What kind of deal, if any, did you make with the dealer for service. Most dealers do not make house calls. There is a chance that something will break and even though it might be covered by the warranty they will require you to bring it in for repairs. Just a thought.
Evereddie is offline   Reply With Quote
Old 08-02-2015, 11:10 PM   #63
Wacipi's Avatar
I foolishly figured I would have a little more than 2 days to have need for any warranty work, allowing me to set up what I need such as a repairman, a company that will tow it to the dealer and reset it at the site, etc. (hmmm, perhaps for that reason not a good idea to undo the tires).
Being in Florida and surrounded by mobile home parks, rv parks and the like, I figure it shouldn't be too hard to find someone. Reliability and price are always an issue here, it's just part of being in Florida you have to accept. I come from the northeast where people actually show up to do the work and actually know what they are doing. Down here people are so desperate for jobs since industry other than tourism is almost non existant (Gulf Coast) that they come down here and start any business they can even if they have no idea what they are doing. So it's always interesting when hiring "pros". Most of them aren't. And some of them show up to mow your lawn, cut a few tree limbs and some odd jobs and run off with your $1,000 the minute you turn your back without doing the work. Yeah, that happened over the past couple of weeks too. I'm batting a thousand here.
Thanks Tom, I'll do that tomorrow and a few other things I learned to look for with these jacks.
2015 Forest River Salem T29FKBS - Super newbie on every level
Wacipi is offline   Reply With Quote
Old 08-02-2015, 11:15 PM   #64
Wacipi's Avatar
Tom, it has current because the extract still works, but when I hit retract it's dead, although I did get a momentary glitch of operation one or two times. It's like the connection from the button is shot, loose or something else or just broken. After only using it a few times, chances are they wore it out on the dealer lot.
After reading some other folks issues with these, and there are many, I am thinking the rocker switch contacts... maybe. I did try blowing on it this morning and I think it actually worked for a split second after that. Saw somewhere where there is a product to clean contacts and it worked for someone. Think for the life of me I can remember the name of the spray? nope
Old 08-10-2015, 12:33 PM   #65
Wacipi's Avatar
Update: FINALLY. Well the switch was bad, then the second switch went bad (on the leveling jacks) Turns out, it was wired wrong and the fuse was going in to the wrong set of wires causing the switches to fry. So one switch is replaced and another is on order, however, we got the jacks down and set.
Also, the trailer, as of today, took me a few days to get up the courage, is now level. I jacked up the axles to the 2 tires on one side, spooky stuff, then quick removed the crap plastic and through under some driveway pavers and chocked up. PERFECT! Couldn't be more level. One shot and it was all done. I had anticipated several lifts. I lucked out though. Thank you all for your help.
I'm sure I'll be back in with more issues, god I hope not!
Old 08-10-2015, 01:56 PM   #66
Evereddie's Avatar
Congrats! You are getting there finally. Soon you might be using it and one of the first things to know about is the proper care and feeding of the black tank. You do know not to leave the black tank drain into the sewer line open all the time, right? You keep it closed until the tank is at least 3/4 full then dump. Have you researched what kind of treatment you will put in the tank? Suggest reading up in the GEO method if yu have not already done so.,
Old 08-10-2015, 02:01 PM   #67
Wacipi's Avatar
Yes, I know about leaving the tank closed and waiting to empty. Haven't started using it yet, actually, want to do a "dry" run first. As for chems, I got something to start off with, but intend to do some reasearch. I will look into that method, hadn't heard of it. Thanks Ed
Old 08-11-2015, 01:54 PM   #68
Wacipi's Avatar
Eddie, I checked in to the GEO method, very doable and makes sense.
Now that the unit is level and just the one switch to the jacks to replace, I am several steps closer to wrapping this up and to start staying in it a few days a week, back and forth to the house while it is on the market, which will hopefully happen next week, the set backs with the TT has put us back a couple of weeks, but no real harm done.
The company I finally got to come out and fix the switch issues with the stabilizer jacks turns out to be a huge company that does everything including warranty work for forest river as well as.... big bonus.... they will come and fix everything on site and if they can't.... THEY WILL COME GET IT AND BRING IT BACK! Finally. Now, if I can just get them to teach me how to tow, I'll be all set, one stop shopping. Otherwise, I really need to learn if phase II of my plan is going to work.
Old 08-11-2015, 03:04 PM   #69
Scubanut's Avatar
Tractor Supply Co (TSC) has all kinds of earth anchors including up to earthquake rating. Stick a few of those into ground with some steel cable running around you axle or other points and your trailer will not be blown over or move.
Name:	ImageUploadedByForest River Forums1439323566.944114.jpg
2012 F150 FX4 Crew 5.0
2012 Coachman Freedom Express 292BHDS (outdoor Kitchen)
Scubanut is offline   Reply With Quote
Old 08-11-2015, 03:43 PM   #70
Evereddie's Avatar
That's a real SCORE on finding that company. Congrats.
newbie
