Old 05-03-2014, 02:00 PM   #1
No cold water pressure in shower
When I turn the cold water on in shower I can hear the pump turn on for a second but very little to no flow comes out of faucet. The sink in the kitchen and bathroom work fine. Is there a valve on the pump that might be closed? If so were would I find the pump. 2014 26tbud
Nacho is offline   Reply With Quote
Old 05-03-2014, 02:05 PM   #2
Would suspect debris in the shower faucets. Turn the pump off and completely dis-assemble the shower faucets as well as the discharge.
Old 05-03-2014, 02:15 PM   #3
Herk7769's Avatar
Draining the hot water heater by using the low point drains can allow bits of anode and calcium nodules to be sucked into the cold water pipes. In the spring when you de-winterize, that crud gets blown throughout your plumbing. If cleaning your aerators does not fix this issue, you may need to remove the valve stems and flush out the lines.
HAM CALLSIGN - KC3FFW
Old 05-03-2014, 02:39 PM   #4
Ok thanks I will try as soon as we get back. I hav a limited amount of fresh water at won't be able to flush out lines right now. thanks for the replies
pressure, show, shower, water
