Old 12-27-2018, 08:29 PM   #1
No interior lights
So I'm about to leave and I have no lights working in the trailer. Power for the slide outs is there along with the jack. Checked all my fuses all ok. Breakers are ok. Could a mouse have did something I trapped one the other day and had lights before that
Petedeb is offline   Reply With Quote
Old 12-27-2018, 08:58 PM   #2
Check the circuit breaker in the main wire from the cutoff switch. Jack and slide have their own inline fuses and are wired to the hot side of cutoff switch as a rule. Rest of trailer get's it's power from a resettable circuit breaker that is somewhat hidden. Follow hot wire from battery(s) to cutoff switch and from the switch follow it along to a small box with two wire studs on it. On the side will be a small "bump" that when pushed will reset the breaker.
After reset you should be good to go.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 12-31-2018, 06:03 AM   #3
Look at ground wires that attach to frame bybthe battery. Great source of problems
pdqparalegal1 is offline   Reply With Quote
