Old 08-01-2016, 10:43 AM   #1
Power tongue jack keeps blowing fuse
My power tongue jack keeps blowing fuses whether on battery, shore power or connecteed to my TV. It came with a 15 amp inline fuse but im not sure if that is the right size or not. I have a salem cruise lite 33 ft bunkhouse with the power package. any help would be great.
helomech45 is offline   Reply With Quote
Old 08-01-2016, 11:01 AM   #2
fonzie's Avatar
I have a 30 amp fuse in for my jack, what jack brand and model # do you have? Here is manual for LCI jack. Recommend 30 amp fuse.
http://www.lci1.com/assets/content/s...ers_Manual.pdf
Fonzie
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 08-01-2016, 04:42 PM   #3
Head Rambler
Most all tongue jacks that I've seen recommend a 30 amp or larger fuse. As Fonzie said above, post the model and brand of the jack and we can help look it up if you need it.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-02-2016, 08:24 PM   #4
I got a 30 breaker cause mine kept blowing fuses.
2014 30QBSS - Salem Travel Trailer
2000 Ford Excursion 7.3 4X4
pkthomas is offline   Reply With Quote
Old 08-03-2016, 01:06 PM   #5
Mine has a 30 amp fuse however if the jack goes to low or high and starts "clicking" it blows the fuse every time! Matter of fact when I did the walk thru with the dealer they had top replace the fuse.
I would be interested to know why. I have not contacted the dealership since it did it again to me.
I carry extra 30 amp fuses for now
Lacrosse40 is offline   Reply With Quote
Old 08-03-2016, 02:22 PM   #6
Tom48's Avatar
I stop mine the instant it clicks if I don't catch it before and no blown 30 amp fuse yet.
Seems to me that if fuse blows from normal use something is bad WRONG. 30 amp should be fine. If it blows, suspect in adequate wire size for the run, bad motor on jack OR WAY THE HELL OVERLOADED
Tom48 is offline   Reply With Quote
Old 08-03-2016, 02:30 PM   #7
Wildcat661's Avatar
Mine came with 40 amp fuse from factory
On Thursday, was just heading out for a long weekend getaway. Stopped to top up with fuel and noticed my tailgate had come down (not shut properly I guess) right onto the electric tongue jack. This in turn, held the switch on, but, because of the size of the fuse, proceeded to burn out the jack motor before the fuse finally blew. Wires melted, really strong burning odor, etc. Luckily, was able to pick up a manual jack and therefore not ruin out weekend.
Why would the manufacturer put in a 40 amp fuse in a 30 amp trailer?
Wildcat661 is offline   Reply With Quote
Old 08-03-2016, 05:12 PM   #8
The wire is to small and forme a resistance and that criate heat and the fuse blow
when the motor need a lot of courant to power the jack.
Replace the wire with biger gauge and the 30 amps will work OK.
Jonol is offline   Reply With Quote
Old 08-04-2016, 09:09 AM   #9
MartiB's Avatar
My jack was doing the same thing when I had to raise and lower it several times. I was told that when it hits the stop on retraction, it causes a surge in the amps that blows the fuse. I had pretty much been doing that. A suggestion was made to bring it slowly to the top then down about a half inch or so. Draw a line on the pole and then only retract it to that point which will keep it from hitting the stop.
MartiB is offline   Reply With Quote
Old 08-04-2016, 10:22 AM   #10
I had one do the same thing. It turned out to be an interal issue and I just replaced it. It would have been more expensive having them try to chase down the issue at their hourly rate. They are cheap. I found a 3500lb unit for $94 shipped on Amazon.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 10 so far
DocGTO is offline   Reply With Quote
fuse, power
