10-01-2017, 08:36 PM
Putting on cover and walking roof of 196bhxl
I am getting ready to put my cover on my 196bhxl and I am not a small person. I am over 300 lbs and I am wondering if it is going to hold my weight. Am I going to have any issues with my weight on the roof while I walk all over it? This is my first TT and I just want to see if maybe I should have someone lighter get up there.
10-01-2017, 08:56 PM
I just looked up your model online. I run about 250 + or - 10# and I get on my roof of my hybrid dual axle SHamrock 183. HOWEVER, I can do most of the work I need to do up there from a 12 foot stepladder propped against the side... whichever side I need to be on. If I do get on the roof, I generally am kneeling (with kneeling pads on).
I park under a canopy cover, but I don't think I need to caution you to soften all the sharp edges before putting on the cover. I would use large diameter pipe insulation, split open and some Gorilla tape to hold it on those sharp edges on the roof and corners of the RV to lessen the chance of tearing in snow loads and wind.
2014 Shamrock 183
10-01-2017, 10:05 PM
I was going to try and do it just with a ladder on the sides, but most videos show someone getting up on the roof. Seems to make it easier. Planned on cutting up a "noodle" and using it on the down spouts.
10-01-2017, 10:15 PM
take it from me... 95% of roof maintenance does NOT require getting on the roof, especially if you are as big or bigger than me...
last time I washed the roof, which I do twice a year, I did it from the ladder... If I get a smaller helper, then let them get on the roof... but NOT necessary much of the time... and like I said before, I crawl on hands and knees when I do need to be up there...
2014 Shamrock 183
10-01-2017, 11:07 PM
Instead of putting "noodles" on all the sharp points. Mark them all with a piece of chalk or soap and bring the cover into a canvas shop and have them sew on vinyl reinforcements. That's how it's done with boat covers all the time.
10-02-2017, 08:41 AM
Gonna try to put it on without getting anyone on top. I am 6'4" so it probably won't be much of an issue. That is a great suggestion about getting add ons sewed on. Probably won't spend the extra money to get add ons made in the cover. Might just cut a towel. That way I can tape them in place. The noodle might slide off during the instal.
10-02-2017, 10:46 AM
On our water spouts, I use tennis balls with a X cut into one spot for the spout. Ball stays in place and protects the cover well.
Allan and Angie
with our little dog Phoebe
________________________
2018 Hemisphere 272rl
2017 Ford F250 XLT 4x2 6.2L 3.73
10-02-2017, 02:32 PM
Like the tennis ball idea as well !
10-02-2017, 04:53 PM
This is a dangerous undertaking. It would be very difficult to put a cover on using a ladder. There are multiple obstructions such as the roof air, plumbing vents and ventilation vents. For one, ladders have a weight rating. They can be very unstable when reaching out and leaning over which you will have to do a lot of. You also have to consider that you may have some wind movement and these covers can easily kite (a hazard in itself).
If walking a camper roof, there a lot of obstructions that can be trip hazards, especially if you are unstable on your feet. I was on the roof trying to cover a 28 ft class C. With two knee replacements, I was totally uncomfortable. Aside from personal weight, you also have the weight of the cover which is initially in the same area as the body. Personally, I would enlist someone with agility to walk the roof or not put it on at all. It is not worth the gamble.
10-02-2017, 05:28 PM
Yes be very careful when putting the cover on the roof. Our 25 foot class c was a challenge the first time. Watch for those vents and do not step on your solar panel. I put my foot through the sky light over the bath room. Nice job for this spring to replace it. Take the anti bellowing devices off of the slides( we have 3 of them) and cover those sharp drain eves troughs on the corners.
Brandon 2
2500TS
