Old 06-22-2018, 08:50 AM   #1
Range Vent and Smoke Detector
I can't find the Range Vent exhaust port. Does the Hemisphere only have a fan and filter? No outside venting? Every time we cook something we set off the smoke detector. It's so sensitive, we set it off using our toaster and there wasn't even any smoke!
RobH063 is offline   Reply With Quote
Old 06-22-2018, 08:57 AM   #2
cavie's Avatar
Look at the front of the hood. See any louvers? if you do it blows back in your face. It is useless junk. The filter may stop some grease but that's it. You get the smoke. You can install a wall vent behind the hood as it is designed for. I'm doing mine this week.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
vent
