Originally Posted by nayther
You missed my point. The primary purpose of Bearing Buddies (not EZ lube) is to prevent water from getting into the hubs, hence the spring, I don't think EZ lube axles have the spring. Are you sure they are the same design, not seen that before.
I didn't miss your point. I've had bearing buddies on several boat trailers over the years and I understand how they are spring loaded to keep pressure on the grease. The EZ Lube type are not spring loaded, but the idea is to keep the void full of grease so that there is no place for water to infiltrate into the bearing area. Again the key is rear grease seals, (which additionally are just as important on Bearing Buddy systems). Without correctly installed, good condition seals, water can get in when immersed. The big difference between the Bearing Buddies, and EZ Lube, is that BB's force grease from the front to the back, through the outside bearing onto the inside bearing, allowing for air pockets to form, and EZ Lube which pumps grease through a passage that comes out behind the inside bearing, between the seal and the bearing, which forces grease through from the back of the bearings through to the front and all air will be displaced. We could argue all day as to which is better in a marine application, but the agreement would always come down to maintaining the seals and bearings for optimum performance and maintaining adequate grease on a regular basis.
PS I wasn't aware of EZ Lube in marine applications until recently myself.
