Old 09-17-2018, 11:42 AM   #1
Re-packing hubs, e-z lube axles
We have a 2014 Salem Hemisphere. Haven't had the hubs repacked yet so I know I should be looking into it....they say do it once a year, but we didn't
have it out last year. This year we did do about a 3,000 mile trip. I can't find anything in the instruction manual that refers to the "e-z lube axles" and not sure what that means. I haven't found any zerks that I can see.....
Salem Lite Hemisphere 232IS
Ford F-250 Super Duty Lariat Crew Cab v-10
jas451 is offline   Reply With Quote
Old 09-17-2018, 11:46 AM   #2
Prime Member
I used the EZ-lube fitting to grease my axels and ended up with grease filled brakes. I had to pull all 4 wheels apart, clean them up and replace 2 of my 4 brake assemblies. I HIGHLY recommend pulling your brakes apart and packing the bearing by hand the old fashioned way.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
Forever in my memory and in my heart. Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 09-17-2018, 12:07 PM   #3
You won't 'see' any grease zerks unless you remove the rubber plug on the wheel center cover and hub center cap. And maybe not even then unless you dig around in the grease.
I suggest you visit Dexter's web site or the many YouTube videos on how to utilize the EZ-Lube feature.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 09-17-2018, 12:07 PM   #4
RSchleder's Avatar
I also have had bad luck with EZ lub hubs. After filling up the brakes with grease, I stopped using them.
IF--you insist on using the EZ lub system, GOOGLE and watch the on-line video(s) a couple of times as there is a specific process to be followed!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 09-17-2018, 12:36 PM   #5
StlClay
I recommend you have a qualified dealer do it before next trip. If they are good, they will check entire undercarriage and suspension and tires/brakes. Also if you don’t do it each year, you normally void any warranty you may have. Check your paperwork.
2014 MiniLite with
Nissan Frontier
Stlcaly is offline   Reply With Quote
Old 09-17-2018, 12:42 PM   #6
sfsgm's Avatar
It's a very easy process to do yourself. If you want to spend several hundreds of dollars, take it to somebody that "does" brakes.
2016 Nike Take Down Wrestling Shoes
42 ft square Dollamur high school wrestling mat
sfsgm is offline   Reply With Quote
Old 09-17-2018, 12:57 PM   #7
No problem at all
I followed the instructions in the Dexter manual that came with my trailer and have never had a problem repacking my z lube bearings. You need to use a hand grease gun not a powered one and use the proper Grease when repacking them. The tires need to be spun while you are pumping the grease in otherwise you will get leakage behind the rear seal. I trust myself doing these things more than I would trust a dealer
Strigflag is offline   Reply With Quote
Old 09-17-2018, 01:05 PM   #8
EZ lube hubs
We had a Rockwood Mini Lite. I used the EZ lube system every fall before we parked it for the winter. Had no problems. You must pump the grease in very slowly and spin the tire. We now have a Forest River Vibe. It has the same hubs. Makes me happy because of the ease.
GaryK. is offline   Reply With Quote
Old 09-17-2018, 01:07 PM   #9
Denver To Yuma In 90 Days
You know...not everyone is a mechanic or even mechanically inclined.
Doesn't matter how "easy" it might be...
JohnD10 is offline   Reply With Quote
Old 09-17-2018, 01:37 PM   #10
Recently new!
Paulie1138's Avatar
Send a message via AIM to Paulie1138
.....But JohnD10, some skills are easily learned to save hundreds of dollars. However, everybody is different, and willingness levels vary.
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
Paulie1138 is offline   Reply With Quote
Old 09-17-2018, 01:45 PM   #11
Look at his. There should be a pop off plastic cover at the end of each axle. Under the cover you will find a grease fitting. CAUTION, do not pump too much grease as you run the risk of blowing out the rear seal. Just do 1 or 2 pumps or just enough to feel a slight resistance.
bzac1954 is offline   Reply With Quote
Old 09-17-2018, 03:03 PM   #12
I have EZ Lube fittings on my boat trailer for 12 years and camping trailer for 4 years. I pump in grease until the old grease comes to front. I have never had grease go out the rear seal.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
Old 09-17-2018, 04:02 PM   #13
Send a message via MSN to Tiggerdad
I repack every year. Have found an occasional spalled roller. I have also found damaged brakes and broken wires on the magnet which meant that brake was NOT working.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 09-17-2018, 09:37 PM   #14
Happy Camper
Do it yourself or
"Pay-To-Play"
Johntgif is offline   Reply With Quote
Old 09-17-2018, 09:50 PM   #15
I pull my hubs, inspect the bearings and repack, replace the rear seal, and pump till the grease just starts squirting through the front bearing. One or two pumps will only squirt a little grease behind the rear bearing and really does nothing as far as greasing the wheel bearings. While your doing all this, (after inspecting the brakes), adjust your brakes for proper operation. That is what I would consider a proper hub, bearing and brake service. How often depends on how much you haul it. First thing to do is watch the You Tube video on how to use the Easy Lube axles. Depending on your experience you could also watch on how to adjust the brakes.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
Comanchecreek is offline   Reply With Quote
Old 12-17-2018, 08:35 PM   #16
I agree, but I think the seal leaked on my ezlube axle. Not a fan at all. I had not used the ezlube method. The seals are also made in china. Says so on the seals. They also now state in the video instructions to add a layer of the red formagasket. So, it sounds like they found their seals had a problem. Used brakleen to clean all the brake parts. Only had one that was real bad. Hope the brakleen works. Looked very clean when I finished.
ekfinch is offline   Reply With Quote
Old 12-17-2018, 09:27 PM   #17
How do you do-it-yourselfers jack up your rig when performing this service?
TV - 2002 GMC Yukon XL 2500, 8.1 liter (496ci), 4L85e & positraction with 3.73 gears
TT - 2013 Dutchmen Aspen Trail 3130 QBS
Drinks of choice: woodford reserve, knob creek & any great bourbon-just about any of San Diego’s craft beer and Pabst Blue Ribbon
Beachbourbon is offline   Reply With Quote
Old 12-18-2018, 08:06 AM   #18
^^^^ Jack up with Floor jack and put jack stands under axle.
Rdeejr is offline   Reply With Quote
Old 12-18-2018, 09:22 AM   #19
LevelUp jacks, one side at a time. Before LevelUp, a five ton floor jack.
Old 12-18-2018, 09:36 AM   #20
^^ and if you don't have an auto leveling system... floor jack, bottle jack or Trailer Aid/Trailer Helper.
axle
