Old 11-18-2014, 10:23 PM   #1
Rear bumper hitch
Has anyone added a frame mounted receiver hitch? If so what did you install?
I want to install a hitch so I can carry bikes, but I don't want to mount it to the existing bumper.
2009 Chevy Silverado 5.3L Z71
2014 Salem 281QB
tmas is offline   Reply With Quote
Old 11-18-2014, 10:35 PM   #2
Poppy94's Avatar
Look at my album. I had a custom one built for one of my trailers. Square tubing with receiver hitch bolted to rv frame, pulled 3000 lbs no problem
Poppy94 is offline   Reply With Quote
Old 11-20-2014, 07:52 PM   #3
I've been looking into this. You are right not to mount anything to the bumper. I found multiple options on etrailer that can be welded right to the frame rails which is what I'll do in the spring.
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
Old 11-20-2014, 08:29 PM   #4
You may find you're opening a can of worms, as this subject tends to polarize the membership. Many folks say don't do it; a lot of us have had no issues.
That being said, here's pics of mine. Dealer installed. Had to wait to pick it up 2 weeks so a certified welder could add it. I've been hauling my bikes 3 seasons. Remember that beefier is better. Don't bolt something to the bumper.
ID:	66676   Click image for larger version
ID:	66677   Click image for larger version
ID:	66678   Click image for larger version
2011 Traverse LT, 3.6L, FWD
Old 11-21-2014, 10:39 AM   #5
Yes, yours is welded to the frame rails, it is only attached to the bumper as a secondary stabilization point. Primarily the weight is being held by the frame rails. Basically I'm going to do the same thing.
2010 Chevy Suburban
Old 11-21-2014, 09:32 PM   #6
Stormrider151's Avatar
I tried to get my dealer to attach a frame mounted hitch but they wouldn't do it. They said the frame was too light weight. I just gave up on the idea. I've seen many who have the hitch's with no problems at all. Lippert tries to make there frames as light weight as possible in their effort to keep trailers as light weight as possible.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 11-21-2014, 09:44 PM   #7
Plain Old Member
We've done it on a few other rigs, but they had sufficient structural steel frames to weld to. Fortunately, our new SOB came with a 2" receiver hitch welded / bolted to the frame with a capacity of 300 Lbs. Perfect for a bike rack, which was what I wanted it for. It actually looks half way decent, but I'd love to do a shade more welding on the mounts. It's made by Lippert, on a Lippert frame. I don't like Lippert, but, they made the frame and the hitch, so I don't have to deal with Lippert saying "can't do that" or "voids warranty". Far better than what the Silverback had with the puny 1-1/4" hitch that barely held the bike rack itself.
My 2 cents: If you have a structural I-beam frame, or box tube frame, and don't mind voiding the warranty, go for it. We did before. If it's the manufactured I-beam frame where 3 pieces are welded together, I would not recommend it.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 11-21-2014, 10:56 PM   #8
My Rockwood 2703ws is heavy enough as it is with opposing slides on the tail end. I just received a Curt front mounted hitch for my f-150. A little more weight on the front of the truck should level things out a bit. Has anyone else made this mod to their truck? Saw a video on you tube of installation.
Rockwoodjoe is offline   Reply With Quote
Old 11-21-2014, 11:01 PM   #9
Plain Old Member
Seen several of those somewhere here on the forum. Several people have done the rack on the front of the truck with the front receiver hitch. I'll be looking at that as a possible option later, when the kids bikes get bigger. We haul 2 on the back, but that's it. For now the small ones go in the back of the truck. A 4-bike rack would seem a little much on the rear for me.
Old 11-21-2014, 11:23 PM   #10
Plain Old Member
Here's thread that might interest you. Plenty of ideas for bike racks. You have to get several pages into it before you get to plenty of pictures. Front of trailer, front of truck, on top of bed cover etc etc.
http://www.forestriverforums.com/for...ack-55961.html
And here's a link to just one of the front hitch manf.
Bodiak Hitches
Old 11-22-2014, 12:26 AM   #11
Denver, CO
garbonz's Avatar
Front hitch's are easy to install and are very useful. ETrailer is a good place to get them as is Amazon. Takes about an hour to install on that Chevy of yours
2017 Fuse 23T
Old 11-22-2014, 12:34 PM   #12
I've had a receiver hitch on the front of my 'burban for 2 years now. I keep my generator up there, inside a box that keeps it out of the rain but I can open the sides while running. The truck blocks the noise and dampens all of the vibrations. Since that is already up front that's why I want to add one to the rear of the camper for bikes. I might try the genset back there but I don't think I'll like it between the noise and vibration.
2010 Chevy Suburban
hitch
