Old 05-30-2014, 06:58 AM   #1
Recent 2k Mile Trip with 282RK - How Many Problems?
None. Zero. Zilch. A big goose egg.
This unit is great. Seriously the only issues we have had is the radio remote is missing and the spare tire carrier was missing a bolt. I highly recommend giving the Salem line a look.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 05-30-2014, 08:51 AM   #2
tlambert's Avatar
Nice. We have this same TT ordered now and hopefully will get it within the next few weeks.
Have did any mods to it so far that might make things easier that you can share?
Tim
tlambert is offline   Reply With Quote
Old 05-30-2014, 09:05 AM   #3
No real serious mods yet. I did install a battery disconnect switch on the side of the battery box to use when the TT is in storage. Otherwise the battery goes dead in about two weeks from the ancillary devices in the TT.
We also put a foam topper on the mattress. That thing is hard!
An upcoming mod will be to install doors on the TV hutch in the bedroom. The cabinet doors under the TV in the "den" are the perfect size to cover the hutch in the bedroom and our dealer said he can order them from FR. We don't use a TV in there, so I will install shelves and the doors to cover them. This will provide more bedroom storage.
Lee and Anne
Old 05-30-2014, 09:09 AM   #4
epicloopers's Avatar
I have a Salem Hemishere 312QBUD and we have also had no issues out of ours. We did the foam mattress topper too!
2014 Salem Hemisphere 312QBUD
2013 Ford F250 PSD
epicloopers is offline   Reply With Quote
Old 05-30-2014, 01:35 PM   #5
tlambert's Avatar
Teamfour, There is something white under your camper to the right of the door, just wondering what it is?
I noticed the firm mattress when we were looking at new ones. The cabinets in the bedroom is a good idea if you need the storage.
Also I am 6'1 and my feet hang off the end of the bed. I think I might have a fix for that. When we get our camper I will post up what I do.
Tim
Old 05-30-2014, 02:40 PM   #6
That is a 5x5 plastic fence post that I mounted to hold 25' of sewer hose. Search for fence post storage and you will find quite a bit of info. It is a great solution for getting the sewer hoses out of the pass-through compartment.
Lee and Anne
Old 05-30-2014, 03:15 PM   #7
tlambert's Avatar
Yup that's what I thought. I have been reading about them. Just wasn't sure why at that position.
Although I guess it's convenient to where the black water tank valve is on the other side.
Could you post some pics of what and how you mounted it on yours.
Oh and what are doing about hooking up the gray water hose at the rear to the black water hose at the front?
Tim
Old 05-30-2014, 03:34 PM   #8
(Tongue in cheek) All are missing awning pole tie downs.
Old 05-30-2014, 04:41 PM   #9
On the rear grey water drain hose: we have a sewer hose Y connector that allows us to run sewer hoses from the forward and rear connections to the Y to the drain. However this is only worth doing for real long stays. It is easier really to just dump the black, the forward grey, then move the hose and dump the rear grey.
Here are some pics of the fence post mod: (sorry for the pics being sideways)
ID:	53855   Click image for larger version
ID:	53856   Click image for larger version
ID:	53857   Click image for larger version
Lee and Anne
Old 05-31-2014, 01:03 AM   #10
tlambert's Avatar
Not a problem. Thanks for the pics!
On the hose connections that is the only thing I could think of doing also. I just hated the thought of having to deal with 2 hoses also.
I have been trying to get all the info I can prior to to getting the TT. I am going to be pushed for time on getting mods done before we leave for a week of vacation. I figured if I can get all this worked out now then when I get it home hopefully it will be less time doing the mods.
I appreciate the info and if there is anything you can think of that would be good to add or change post it up.
Thanks Tim.
Tim
