Old 01-26-2016, 06:48 AM   #11
satdog01's Avatar
My Flagstaff has the two caps just under the water heater door. When doing the winterizing, I cracked the hot water in the camper prior to removing the caps. This procedure pulls almost all of the water out of water heater. Also relieved any pressure in the system. Pulled the anode to be sure. Like having access to low point drains outside so I can monitor progress of the water removal.
Marriot II on Wheels 2017 Flagstaff Classic 832OKBS Diamond Pkg
2013 GMC Denali crew 6.6L 2500 HD DMAX w\Alison Trans
Pepper 🌶 Pomeranian rescue 204 nights as camping buddy
Days camped in FR, 2011 = 20, 2012 = 57, 2013 = 59
....2014 = 39, ‘15 = 52, ‘16 = 77, ‘17 = 81, 2018 = 4
Retired :
satdog01 is offline   Reply With Quote
Old 01-26-2016, 01:51 PM   #12
I have valves
BRUCEANDCYNDI is offline   Reply With Quote
Old 01-26-2016, 02:22 PM   #13
AquaMan's Avatar
I usually open all the faucets prior, makes for a faster more efficient drain.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 01-26-2016, 09:04 PM   #14
Thanks for reply, I am not at where Rv is stored right now, however I believe the pantry is close to being over the top of where the hoses come out of belly. I have winterized it and water came out of the white hose and it has a close off valve on it. I drained all water out and left it open, but as I said the red and blue have no cap, no plugs, no threads, just open hoses which go thru the black under belly, beside the white hose and is sealed up all around all three hoses. I will go tomorrow and see if taking drawers out of the pantry will expose the hoses or cut off valves. Why in the world would anyone put the cut off valve inside and do away with the drain caps outside where they could be drained at same time low water was drained? Now I am worried they may be frozen. It has been 18 degrees here. thanks for help, I will tell what I find after inspection Wednesday
topkattkg2 is offline   Reply With Quote
Old 01-26-2016, 09:56 PM   #15
They are inside so they will not freeze when you are using the RV in the winter. The drains with caps will freeze easier. Our flagstaff had the valves inside its a better setup in my opinion.
drc343 is offline   Reply With Quote
Old 01-27-2016, 06:30 AM   #16
Sounds like the factory has improved their design between 2015 and 2016, or some TT lines do things differently since FR is not a single company. My Georgetown has the standard plugs, there is a clean line with no plug which is the water tank overflow, a white line with a plug which is the water tank drain (low pressure side of the pump) and the other line is the high pressure side of the pump (cold, hot and the rest of the piping in the unit.) Actually, as others have pointed out, the plugs make those lines susceptible to freezing since they are under the unit and internal valves would be a much better solution. If you don't have plugs you must have valves inside somewhere, perhaps in the water pump bay. Much better solution and some members have added these valves themselves and just left the plugs off.
In addition, the water filter is on the high pressure side of the pump and it won't drain by itself. Air pressure winterizing should empty it, but it is better to open it and dump any residual water and remove the filter during winterization.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 01-27-2016, 06:42 AM   #17
nomad297's Avatar
This is 100% fact. It's ironic that on most RVs, the pipes that are designed to keep your pipes from freezing are piped such that they will be the first thing to freeze if you are winter camping.
I wish my low point drains had valves hidden inside of the conditioned area.
Bruce
nomad297 is online now   Reply With Quote
Old 01-27-2016, 10:29 AM   #18
Will be going to Rv today and try to find cut offs. I hope u folks are correct, I have checked around water pump and could find no cut offs, also the hemisphere does not have a built in filter. The water pump is in the very front of Rv inside the pass thru storage area and 20 feet from where these hoses are located. Will update this evening, thanks again for all the thoughts.
Old 01-29-2016, 10:23 AM   #19
Well after 3 hours of searching for where the red and blue drain hoses go to and how to open the drains for them, l have found nothing. They are not behind the pantry, stove, island sink, furnace,water heater or water pump. I give up, I guess I will try contacting FR Salem and see if can help. One last idea is maybe the manufacture forgot to install the plugs or don't install them anymore. who knows? Anyway thanks to all who tried to answer the question.
Old 01-29-2016, 11:01 AM   #20
Ford Idaho's Avatar
Does it have bench type seating?
If so pull the cushions and remove the chip board they sit on.
If they are screwed on remove the screws.
If they are in a cabinet they might be behind a false panel.
water
