Old 11-19-2017, 08:07 PM   #1
runner48's Avatar
Refrigerator/ Outlet
2016 368RLBHK
I lost power to fridge and an outlet next to the fridge. I checked the circuit breaker and the fuses and everything is in working order. I can’t figure out why there is no power to the refrigerator or the outlet next to it. There was an overload which caused the overload, I had a toaster oven and an electric coffee maker on when the overload occurred. Any info on anything else I should check?
runner48 is offline   Reply With Quote
Old 11-21-2017, 09:40 AM   #2
SeaDog's Avatar
Check the GFI in the bathroom or located elsewhere that may solve your problem. Let the forum know what you find hand how you correct it
Retired Navy
2016 Flagstaff 26 FKWS
Old 11-21-2017, 12:10 PM   #3
runner48's Avatar
Well I had to stop by dealer and inquired about my issue, I was told by the service department to check the inverter located in the front compartment for a fuse burnout, I checked the inverter and upon replacing the fuse it corrected the problem. I was informed that the inverter absorbed the overload which protected the residential refrigerator and the electrical outlet. I sure am thankful, this could have been a costly repair. I am thankful that I was provided with good advice that saved me from taking my rig in for service as I am a full time RV’er. Hope this Experience helps you all out there[emoji4]
Old 11-21-2017, 12:38 PM   #4
bikendan's Avatar
I think you would have got quicker solutions, if you had told us it was a residential fridge, in your original post.
That would have indicated checking the inverter.
Most RVs don't have inverters, so solutions follow a different path.
I'm posting this suggestion, for those who may have the same issue in the future.
refrigerator
