Old 10-02-2014, 03:40 PM   #1
Trujillofam3's Avatar
Refrigerator says check
Should be auto and switch to
Propane automatically if we have no hookups.... Our battery is low as expected and although I have manually set it to gas, it still says check. Any suggestions? Salem 32bdhs
Thanks!
Currently in Yosemite :-)
Trujillo family
Camping since 1996
Travel trailer purchased 7/2014
Salem 32BDHS
Trujillofam3 is offline   Reply With Quote
Old 10-02-2014, 03:43 PM   #2
Dazed & Confused
M&K Hoffman's Avatar
Propane automatically if we have no hookups....Our battery is low as expected and although I have manually set it to gas, it still says check. Any suggestions? Salem 32bdhs
Thanks!
Trujillo family
Camping since 1996
Salem 32BDHS
How low is your battery? Refrigerator needs 12 vdc. to run even on LPG.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
Old 10-02-2014, 03:44 PM   #3
Ahhhh thank you lol. That makes sense and we learned something new. Thank you very much!
Trujillo family
Camping since 1996
Salem 32BDHS
Old 10-02-2014, 06:54 PM   #4
HONDAMAN174's Avatar
X2. Hook up your tow vehicle 7-pin plug and run the vehicle for a while for a slow charge. For faster, hook jumper cables to the batteries (pay attention to pos and neg to not hurt your tow vehicle!) and run at 2000 Rpm's for about 30 minutes.
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
Old 10-06-2014, 09:47 PM   #5
Also I believe the check will come on at least it did with my 2006 Salem if the propane didn't light with in 3 attempts
I always had to "bleed" the line by lighting the stove if we had not used it in a while then fridge would lite usually first attempt
Just been my experience as well.
nothinken is offline   Reply With Quote
Old 10-07-2014, 11:31 AM   #6
+1, light the stove and then anything downstream of the fridge, if there is anything, on your model.
techntrek is offline   Reply With Quote
refrigerator
