Old 05-06-2015, 10:38 PM   #1
Golfnbike13's Avatar
Replace 120v fridge with propane version
Is this possible? I've had some tell me it is, and some say it's not unless the camper was designed for a 2-way fridge with propane. It's a 195bh that came stock with the 120v bar fridge.
Golfnbike13 is offline   Reply With Quote
Old 05-31-2015, 09:30 PM   #2
M1k3y2004's Avatar
you could but would require a lot of work.
M1k3y2004 is offline   Reply With Quote
Old 06-01-2015, 05:32 AM   #3
davel1971's Avatar
since it needs venting through the wall and ceiling, and the fridge itself is well over $1000, if it's even possible, would be ridiculously expensive. Would be cheaper to trade for a different trailer
David & Lynn
Old 06-01-2015, 05:49 AM   #4
Cableman's Avatar
Pick up one of these if you need one to work with out a/c
ARB Fridge Freezer, 50QT (10800472)
15' Coachmen apex 288bhs
10' crossroads zinger (sold)
09 rockwood roo 21ss (sold)
08 dodgeram current TV
Cableman is offline   Reply With Quote
Old 06-01-2015, 06:17 AM   #5
If you just want a fridge without a freezer this popup style 3 way is on sale $532: Norcold Refrigerator without Ice Maker 1.7 - Norcold 323TR - Compact Refrigerators - Camping World
You would still need two cutouts on the side of your trailer, and you would need to run gas to it.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 06-01-2015, 06:25 AM   #6
TN_Cruise_Lite's Avatar
I noticed on at least one new 195BH there is no door on the outside for the fridge, only vents. On older models like mine the door was solid for 110v fridges and I'm pretty sure the propane fridges had vents cut into the same style door. On the one I have there is even a capped-off tee fitting on the gas pipe under the fridge. Shouldn't be that big a deal to install with 110v, propane and 12v all nearby.
2018 Coleman Light 1805RB
2010 Chevy Silverado 4x4
2013 Salem Cruise Lite 195BH (traded)
TN_Cruise_Lite is offline   Reply With Quote
Old 06-03-2015, 04:00 PM   #7
Are these the vents everyone is referring to? I have these on each side of the cabinet that houses the fridge. Click image for larger version
Name:	ImageUploadedByForest River Forums1433365190.566881.jpg
Mine is a 2014 model. The door on the outside appears solid.
Old 06-03-2015, 04:09 PM   #8
TURBS's Avatar
Originally Posted by Golfnbike13 View Post
Are these the vents everyone is referring to? I have these on each side of the cabinet that houses the fridge. Attachment 78944
No
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 06-04-2015, 06:29 AM   #9
Like this:
Can't find an old pic with the vents in the door. The 110v versions don't even have a door on the new models.
Old 07-02-2015, 07:02 AM   #10
This is definitely possible. I just found out a dealer tried to pull a fast one on a friend of mine. When he went to pick up his new travel trailer it had just a 110v fridge even though his contract stated a regular RV fridge. He made them install an RV fridge where the 110v was. Below is a pic of the vents that he said were already in the exterior door like I thought I had seen in 2013. He said that Forest River engineers gave the dealership approval to make the change. One thing I did notice was the compartment was completely sealed with silicone caulk so no CO gas could enter the inside of the unit.
fridge, propane
