Old 03-18-2014, 03:35 PM   #1
Replacement Valves
I broke both my Gray and Black tank dump valve handles, and I'm pretty sure I cracked one of the lines this winter after a freeze.
Will this works as a replacement?
Valterra (TR38) 2-Valve Assembly : Amazon.com : Automotive
Are those the same angles?
I can't really check as my Salem is 300 miles away at the moment.
Salem 27BH
2006 Salem 27BHSS
2012 F-150 SCREW EcoBoost, 3.73, Tow Package.
Woolaroc is offline   Reply With Quote
Old 03-18-2014, 03:55 PM   #2
raspivey's Avatar
That's one of those "measure twice, cut once" situations. I'd have to move some lines slightly on mine, but it's a different trailer. It SHOULD work, but I'd look at some options and then check out the unit again before I bought anything. On the other hand, it's not a really expensive purchase if it doesn't work and PVC is cheap if you have to do a little plumbing.
Old 04-01-2014, 12:12 PM   #3
Thanks Ras. I think it should work. My trailer isn't close (4 hours) away, so I'd like to fix it next time I go up there.
Like you said if it's not perfect, a quick trip to HD for some PVC is all it will take.
2006 Salem 27BHSS
Old 04-01-2014, 12:32 PM   #4
Anyone know the difference between the Fixed vs Rotating Valterra?
Rotating
Amazon.com: Valterra (TR38) 2-Valve Assembly: Automotive
Fixed
Amazon.com: Valterra T38 Fixed Wye Double Valve Assembly with 3" Hub x 1-1/2" Rotating Hub x 3" Bay with Cap: Automotive
2006 Salem 27BHSS
replacement, valve
