Old 04-21-2019, 05:12 PM   #1
Rkss electric service
Our 2018 27 rkss has the breaker box and service under the entertainment cabinet (television stand). I found an additional service with fuses but no breakers in the bottom of the cabinets in the bathroom. Anyone know if there's any distinguishing reason for the 2 locations? Or is it just overflow of space from the main service?
Thanks in advance
greggcowan is offline   Reply With Quote
Old 04-21-2019, 05:28 PM   #2
Lacey's Spring, AL
formerFR's Avatar
generally you are going to have both a FUSE panel, and a BREAKER box, or a combination of both. FUSE panel is for your 12v devices such as lights, fans, awning, slides, etc., while your BREAKER box is for your 120v devices, outlets, and appliances when you are plugged in.
Whether they are separate or in totally different locations matters not, though most rigs have a combined box with both, including your converter/charger.
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx, 100,000+mi since '14... US, Alaska, and Canada... from W.C. Georgia, then W. North Carolina, now Lacey's Spring, AL : )
formerFR is offline   Reply With Quote
Old 04-21-2019, 05:33 PM   #3
thanks former! I should have elaborated.... The main service In the entertainment cabinet is both breakers and fuses.... The other unit In the bathroom is just fuses
Old 04-21-2019, 05:36 PM   #4
Lacey's Spring, AL
formerFR's Avatar
depending on what their labels say, it's just a secondary fuse panel, probably to be closer to whatever source they are tied to.
Old 04-21-2019, 05:37 PM   #5
Lacey's Spring, AL
formerFR's Avatar
send a pic and we might can tell you more...
Old 04-21-2019, 05:39 PM   #6
will do.... I'll snap a few shots tomorrow. Thanks again for the help
Old 04-21-2019, 05:42 PM   #7
Lacey's Spring, AL
formerFR's Avatar
my coach has a fuse panel for the House, in the same 'box' as the Breakers, one in the Inverter bay, and another in the front driver compartment... that's a lot of fuses.
Old 04-23-2019, 01:21 PM   #8
Head Rambler
The small 'service' you found under the bathroom is the remote receiver. It has relays and fuses to operate the remote functions.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 04-23-2019, 04:28 PM   #9
thank you Rambler! I would have never guessed that.... Been puzzling me since we bought it. Mystery solved!
Old 04-23-2019, 04:34 PM   #10
D W
D W's Avatar
Just be very careful of the single wire hanging off of the module. It is the wireless antenna.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator SSI PKG- Reprogrammed 4L80E
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 04-23-2019, 04:37 PM   #11
will do! Lol. Thank you so much again
electric, service
