Old 07-29-2016, 11:33 AM   #1
Roof Sealant
I have a 2015 Salem Hemisphere Lite 266RLBS 5er. Does anyone know what the putty like sealant FR uses on the rear corners of the 5th wheel trailers roof. It is a light tan color to match the rubber roof. It appears that it did not adhere properly to the rubber material and is possibly heading for a leak situation.
Also, the condensation water draining from the air conditioner down the back does not flow into the gutter and out the side. Instead it is going into the metal seam on the left rear corner that has the plastic strip in it and down the inside under the plastic strip. There is a lot of screws down that seam and I see lots of opportunity for leaks. Any ideas how to reroute the flow other than making the trailer unlevel? Sorry, I did not get a photo before returning to storage.
Jim
jbhiggins is offline   Reply With Quote
Old 07-29-2016, 11:53 AM   #2
Tfort's Avatar
Sealant should be Dicor lap sealant.
2000 F250 CC 4x4 7.3L diesel
15 Salem Hemisphere Lite356QB
Tfort is offline   Reply With Quote
Old 07-29-2016, 08:55 PM   #3
Thanks Tfort, I'll see if our local RV parts store can match the color.
Old 07-29-2016, 09:10 PM   #4
The Dicor product should come in tan color as well as others. Good luck.
2015 FR Classic 625D
2011 Toyota Sienna XLE
Dodaman is offline   Reply With Quote
Old 07-29-2016, 09:36 PM   #5
Canadian Member
itat's Avatar
On the flat roof, use self-levelling lap sealant. On the vertical walls I use ProFlex RV sealant.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
roo, roof
