Old 07-16-2016, 05:57 PM   #11
SEARCH??
Originally Posted by NMWildcat View Post
Hi Gary! I'm really not trying to be a jerk when I say this, but there are several really good threads on this problem in this forum that will give you several options in dealing with this. Just doing a search on a/c and freeze would do it I think. Good luck!
He wants information, not instructions on how to search. Search can give too many trails to follow. Know the answer? Give it up.
pdqparalegal1 is offline   Reply With Quote
Old 07-16-2016, 06:59 PM   #12
NMWildcat's Avatar
I did. Search is your friend. 😀
Scott and Liz - Southern NM
Old 07-16-2016, 07:21 PM   #13
Originally Posted by mikel68 View Post
3. Is your condensation drain free from debris? Generally they will leak before they freeze, unless the water has no where to go.
You should see the water dripping off your roof somewhere. If not, your drains are plugged.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
roo, roof
