Old 10-18-2016, 08:06 PM   #1
bhersh's Avatar
Running heat while boondocking
So, I've never really boondocked. We may go to a college football game next month. I have a 356qbq and a Honda 5000 watt generator. I have to turn the generator off from midnight through seven am. Will the battery run the fan for the heat for seven or eight hours with nothing else using the battery? What are my options? More batteries? Thanks in advance.
bhersh is offline   Reply With Quote
Old 10-18-2016, 08:25 PM   #2
Bluepill's Avatar
Most batteries have enough power to run the blower in the heater for 7 hours without a problem. To be sure that the battery is fully charged before turning off the genny, it is smart to use a portable battery charger for an hour or so. The factory converters are famous for not fully charging the batteries.
2008 Itasca Meridian 37H
Old 10-18-2016, 08:28 PM   #3
Moderators' Assistant
bikendan's Avatar
It's best to have at least two deep cycle batteries for dry camping or boondocking.
Also depends on what you set the thermostat at.
If it's cold and you keep it set at 75, the battery may not last all night.
Dan-Retired Firefighter/EMT
2016 PrimeTime TracerAIR 255, pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 10-18-2016, 09:19 PM   #4
Golfnbike13's Avatar
I've used one battery for a night of heat before. It does depend on the temp and your setting but it's possible. Set the temp low and throw extra blankets on bed.
Golfnbike13 is offline   Reply With Quote
Old 10-18-2016, 09:32 PM   #5
Bluepill's Avatar
Also, be aware that the CO alarm will go off when battery voltage gets too low. Some people have been rudely awakened in the early hours by this.
Old 10-19-2016, 12:44 AM   #6
benagi's Avatar
Tell me about it. Anyway to turn that alarm off when going off at 3 am. Don't want to run the generator that time of the morning just to charge the batteries back up .
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 10-19-2016, 02:55 AM   #7
stoppercamper's Avatar
Until our 23ikss gets here, we have a popup (where the windows don't fully zip) and all we do is boondock camp. We have a very nice lightweight fleece blanket that we throw over top of us that is warmer than a big sleeping bag (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1) and trust me I researched a lot of blankets.
The second thing is we use a heater buddy!!! Love Love Love it!!! it uses space technology to put out a lot of heat using very little propane. It's safe, shuts off if bumped. So we turn it on and warm up the camper before bed, that way the heater doesn't turn on for a couple of hours. and it heats up the space way faster than the camper furnace does.
https://www.walmart.com/ip/Mr.-Heate...setts/19294100
stoppercamper is offline   Reply With Quote
Old 10-19-2016, 01:06 PM   #8
You can run a Mr. Heater Buddy or whatever catalytic heater in the trailer with a window cracked open to keep the heat up in the trailer during the day when your not in the trailer so much to save on furnace run time. The furnace motor is the single biggest draw on your batteries so if your gone for more than a few nights you will soon run out of battery power and the generator will not be able to keep the charge up using the built in converter unless you hook the generator to a battery charger with 10 or more amps of output and connect direct to the terminals of one batteries. I dry camp every year for 3-4 weeks when the furnace is usually still required and this seems to do the trick even though I do not have solar panels with this trailer. Even with solar panels dry camping in cooler weather will result in you needing to run a generator eventually every day to keep up the house batteries.
rthomaslyons
2015 Flagstaff 26FKWS
rthomaslyons is offline   Reply With Quote
Old 10-19-2016, 01:39 PM   #9
Our Heater Buddy works very well! We got it during our PopUp days, but have kept it as emergency heat ever since. It will heat the camper with no problem. The propane lasts surprisingly long. How long, depends on how hot you want your living area. Just keep a window cracked to allow some oxygen into the room with the heater.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat 4X4 6.4 Diesel
61 nights in 2016
10 nights so far in 2017
ben31 is offline   Reply With Quote
Old 10-19-2016, 01:51 PM   #10
X2- And dogs too. Mine have flipped out when the alarm goes off. Once I tried to tie them up outside quickly, while I tried to turn the alarm off. They broke loose panicky and bolted in a very dark and nearly deserted State Park. I had to look for them for 20 minutes. I was beginning to panic at that point worrying about coyotes and the nearby hwy.
mtnlvr is offline   Reply With Quote
boondocking
