Old 06-22-2011, 09:32 AM   #1
RV's Wheel Alignment
Has anyone noticed that their unit's tires are wearing unevenly? Could the alignment be out (axles/wheels not being completely square with the drive line of the unit or haul vehicle)?
How can I fix this?
jackfor2 is offline   Reply With Quote
Old 07-26-2011, 12:04 AM   #2
How can I fix this?
Check wheel/tire size installed vs what is on the label on the side of the trailer.
mrwitt is offline   Reply With Quote
Old 07-26-2011, 08:58 AM   #3
What is "wearing unevenly" ? Need a description. By the way, there is no "wheel alignment" since the axles are solid, with no adjustments. They may be mounted to the frame crooked, or bent, causing an alignment type problem, in which case a welding shop will have to correct. Describe your wear issues, and we'll try to help. Picture may help also.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
alignment
