Old 06-25-2018, 05:54 AM   #1
Salem 27 DBK. Hot water tank how to switch between gas or electric
Hey guys, I have know idea how to switch between gas and electric on this hot water tank. It seems to be on electric now. But I want to make sure I know how to use it.
Jeff
Boggs is offline   Reply With Quote
Old 06-25-2018, 06:06 AM   #2
wmtire's Avatar
If you have a Suburban brand water heater, this thread should fix you up:
Suburban's electric switch and much more
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 06-25-2018, 06:51 AM   #3
Lifetimer's Avatar
I have a 27DBK too. Make sure the switch in the trailer for gas is off. Open the cover for the water heater and there is a big on and off switch, just turn in on. If you want to run by gas turn the switch to off and then you can use the inside gas switch.
I leave it on electric as long as my water heater is full of water. If the trailer is not hooked to electric it does not go on. Just make sure you turn it off before you empty the water heater, you will burn the elements if you don't.
Renee and Wayne
Seymour, Tennessee
2018 Salem 27DBK,
2004 Dodge Ram 1500
2 kids, 2 Grandsons, 1 Granddaughter, 3 fur babies
Lifetimer is offline   Reply With Quote
electric, gas, hot water, salem, switch, tank, water, water tank
