Old 09-09-2019, 08:51 PM   #1
Salem 27REI wiring
I always like to find out everything I can when I get a new camper. Iíve located pretty much everything that I can find. I found this fuse which is located behind the beam located at the back of the tongue. You have to crawl under the camper to get to it. Who puts a fuse there? Anyway, before I go tracing it out, does anyway know what it goes to? Iím going to relocate it under the battery cover for easier access. Also would like to find out where the module is located for the remote control of the slides, awnings, lights and stabilizers?
parrott is offline   Reply With Quote
Old 09-10-2019, 04:35 AM   #2
I'm guessing the tounge power jack? As for the remote.... My system in our RKSS is located in the bathroom in a false floor at the bottom of the cabinet for towels etc.
greggcowan is offline   Reply With Quote
Old 09-10-2019, 08:39 AM   #3
Head Rambler
I'm going with Greg. Most likely the fuse for the tongue jack.
Do you know what those two Short-Stops (Circuit Breakers) are for?
P.S. I don't list the 27REI in my list of remote receiver locations, so when you find it if you'd kindly post it's location I'll add it to the list.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 09-10-2019, 09:39 PM   #4
Traced out the wire to the fuse. Itís for the solar power plug for a portable solar panel. Most likely will not move as we probably will not use one.
I found the controller box for the remote under the bathroom sink access panel as told by greggcowan. Thanks
While I was under the rv I check all the connections and found one fairly loose. Tightened them all up. I may at some point move all the connections to the other side of the beam in a watertight box for easy access. Itís mostly connections but could give problems down the road.
Also cleaned up some sawdust left behind. Yes there are some fuses in the remote control board.
ID:	214639   Click image for larger version
ID:	214640   Click image for larger version
ID:	214641   Click image for larger version
Old 09-11-2019, 08:46 AM   #5
Head Rambler
Parrot -- What year is your 27REI? I put that info in the spreadsheet because they move them around from year to year.
Gotta go campin!
Old 09-11-2019, 12:13 PM   #6
2019
Old 09-11-2019, 02:16 PM   #7
Head Rambler
Thanks.
Gotta go campin!
salem, wiring
