Old 08-01-2014, 10:10 PM   #11
M1k3y2004's Avatar
Originally Posted by Cleon View Post
Hi
I am fussy when it comes to attaching anything to a trailer wall as i am concerned about structural integrity. So when it came to mounting coat hooks and a medicine cabinet i knew what i wanted to do but wasn't sure how i would hide it. thats where my wife the "crafty one" comes into play. I will let the pictures speak for themselves. let me know your thoughts. thanks
How did you get the boards to match the wall paneling? looks good. Im interested in doing this myself if you dont mind helping me out on how to.
M1k3y2004 is offline   Reply With Quote
Old 08-02-2014, 10:19 AM   #12
Golfnbike13's Avatar
Originally Posted by TN_Cruise_Lite View Post
Mine is on a swivel mount next to the microwave and the blue-ray is attached with Velcro to the counter below. Used a cord track to control the wires. Swivels to be visible from anywhere including the bunks.
Did you mount on the wall or the cabinet? Does that location allow it to swivel to been seen from the bunks and your bed?
Golfnbike13 is offline   Reply With Quote
Old 08-02-2014, 09:42 PM   #13
TN_Cruise_Lite's Avatar
Wish I'd done some pics but its too late now. A very simple install though. I got this mount from Walmart. Looks like its no longer available but similar ones are out there. I removed the microwave, drilled holes in the side of the cabinet and used large washers on the inside to assure the bolts wouldn't pull through. One year and many miles later i have no issues at all. The TV folds flat against the outside wall and I use a cushion between the wall and TV to assure there is no damage from vibration during transport.
2018 Coleman Light 1805RB
2010 Chevy Silverado 4x4
2013 Salem Cruise Lite 195BH (traded)
TN_Cruise_Lite is offline   Reply With Quote
Old 08-19-2014, 07:14 PM   #14
Salem Cruise Lite 195BH TV mount
I'm doing this same install. So by mounting to through the cabinet it's strong enough to hold the TV?
Old 08-19-2014, 07:27 PM   #15
Hi
How did you hang the medicine cabinet and coat rack on the wall? I didn't think there were studs in these?
Old 08-19-2014, 08:16 PM   #16
Yes, no issues for me. The TV is swiveled toward the outside wall and fastened back with an elastic strap that has Velcro on the ends when traveling. I used large washers inside the cabinet to distribute the load, what little there is. I wouldn't mount a large TV like this but mine is so lightweight and the upper cabinet is designed to support the fairly heavy microwave and whatever you can store above the stove. I only put lightweight items above the burners and have no concerns at all.
Old 08-19-2014, 08:23 PM   #17
What size TV did you use? I've got a 20" but would like to go to a 24" if possible.
Old 08-19-2014, 08:27 PM   #18
Mine is a 20" but if I wanted a 24" I'd weigh them or look at the manufacturer's specs cause the weight difference may be minor.
Old 08-19-2014, 09:04 PM   #19
jawga's Avatar
we mounted a 24 inch in ours byt mounted it on the opposite side of the door
jawga is offline   Reply With Quote
Old 08-19-2014, 09:08 PM   #20
I already have the cable hookups wired to the spot above the counter. So it would be easier to install close to that I think.
mount, salem, tv mount
