Old 05-04-2014, 10:48 AM   #1
Salem Cruise Lite 195BH TV mount
Hi everyone,
I'm a TT rookie and just bought a 2015 cruise lite. It does not have a TV location. Does anyone know if this model has a pre-defined location for the tv mount that the factory allocated? I understand the walls are thinner and they don't have studs like out traditional home walls.
Also is there a best place to run a coaxial cable to the outside from the tv mount location?
tomngo8 is offline   Reply With Quote
Old 05-04-2014, 07:55 PM   #2
jawga's Avatar
We have a 195BH also that didnt come with a tv. we mounted a bracket on the wall at the end of the bed next to the door. this allows everyone to see the tv as well as it is out of the way. i ran our cable under the trailer and mounted a junction box at the end of the bed. the cable runs in the conduit back to where yhe shore cable come out. right now i pull the cable out if the same hole as the shore cable but i'm in the process of mounting a permanent hookup up box on the outside of the trailer. For the trailers that have tv's installed from the factory they mount over the extra counter on the wall. the trailer does have studs but they are about half the width of a normal stud. I used a stud finder to mount our tv racket and used screws that came with our mount. If u want some pics i'll take some if u like. we ended up with a 24" led vizo from walmart
jawga is offline   Reply With Quote
Old 05-04-2014, 08:33 PM   #3
Yes, please show me some pictures. I also wanted to mount the tv in the same location as yours. And funny thing is, i got a tv that is 24 inches with a DVD from best buy too.
As for the coaxial cable, did you have it exposed along the wall to the TV? Also can you take a picture of how you ran the cable as well? And how you ran it to the shore cable box?
Thanks!
Tom
Old 05-04-2014, 09:03 PM   #4
jawga's Avatar
Nope drilled a hole under the bed. wanted to make it look as factory as possible. will take pictures of that also tommorow
Old 05-04-2014, 09:49 PM   #5
Great, can't wait for the pics.
How did you get the coaxial cable to run along the walls to where the TV is hung? I thought the walls had insulations and is not hollow.
Old 05-05-2014, 06:10 PM   #6
jawga's Avatar
I am going to move the cable from where the shore pine comes out to up inder the trailer. Also i added a reinforced bed frame since ours was cracking so the board originally wasnt there when i installed the blue junction box. i just drilled through the floor and resealed with caulking. i unhooked the retaining rings on the conduit that hold it under the trailer so i could run the cable in the conduit. then i reinstalled the retaining rings
ID:	51746   Click image for larger version
ID:	51747   Click image for larger version
ID:	51748   Click image for larger version
ID:	51749   Click image for larger version
ID:	51751   Click image for larger version
ID:	51752   Click image for larger version
ID:	51753   Click image for larger version
ID:	51754   Click image for larger version
Old 05-05-2014, 09:57 PM   #7
Thanks for the pics.
Old 06-24-2014, 08:16 PM   #8
TN_Cruise_Lite's Avatar
Mine is on a swivel mount next to the microwave and the blue-ray is attached with Velcro to the counter below. Used a cord track to control the wires. Swivels to be visible from anywhere including the bunks.
2018 Coleman Light 1805RB
2010 Chevy Silverado 4x4
2013 Salem Cruise Lite 195BH (traded)
TN_Cruise_Lite is offline   Reply With Quote
Old 07-22-2014, 10:11 AM   #9
2016 Avenger 26BH
wall mounting acc.
Hi
I am fussy when it comes to attaching anything to a trailer wall as i am concerned about structural integrity. So when it came to mounting coat hooks and a medicine cabinet i knew what i wanted to do but wasn't sure how i would hide it. thats where my wife the "crafty one" comes into play. I will let the pictures speak for themselves. let me know your thoughts. thanks
ID:	58670   Click image for larger version
ID:	58671   Click image for larger version
ID:	58672   Click image for larger version
ID:	58673   Click image for larger version
Cleon is offline   Reply With Quote
Old 08-01-2014, 10:09 PM   #10
M1k3y2004's Avatar
Do you got any details on this mount and more pictures? I just purchased the same RV and would like to copy your ideal.
M1k3y2004 is offline   Reply With Quote
mount, salem, tv mount
