I have a 27DBUD Salem and want to install a Progressive Ind. HW30C. Can someone point me in the right direction the wires that I need to insert it. I looked in the bathroom close to where the wire to plug to a 30 amp breaker is but didn't find any wires just water pipes.TIA
You will need to decide to either cut the umbilical or remove the 30 amp main from your converter panel for your input.
Here is more information for your reading pleasure.
