Old 05-24-2016, 05:44 AM   #1
Salem Hemisphere 282 RK Tire Pressure
I see a lot of comments on-line regarding the proper tire pressure for my trailer. The inside spec sheet lists 65 PSI as does the Westlake tire side wall for full load. The 2014 282RK arrived with 55 PSI of nitrogen & I have not changed the pressure. Many posts recommend 55 PSI that more may blow out the sidewalls.
I do get some swaying while towing (no sway controller) & am considering adding AIR to bring the pressure to 65 lbs.
Have any Salem Hemi owners experimented with this?
Obrieri is offline   Reply With Quote
Old 05-24-2016, 07:33 AM   #2
Happy Camper
Tonylmiller's Avatar
The BEST thing for a tire carrying a heavy load or running at high speed (or both) is to inflate the tire to maximum air pressure. Lower air pressure allows for more flexing of the sidewall, which generates heat and can destroy a tire. Inflate your tires to 65 psig cold immediately and keep them there, if that is what the sidewall says.
I used to be a Tire Construction Engineer for Dunlop.
2015 Salem Cruise Lite 262BHXL
Towed with 2015 Chevy Silverado
Tonylmiller is offline   Reply With Quote
Old 05-24-2016, 09:51 AM   #3
This^^^ In addition do not exceed the speed rating which has typically been 65 mph for an ST tire. Some are now rated to 80 mph, but there is no reason to tow that fast IMHO.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 05-24-2016, 01:08 PM   #4
Thanks for your real expertise on this matter. I would appreciate your opinion on bumping the tire pressure to 65 PSI by adding air vs nitrogen as the tires are currently inflated with.
Old 05-24-2016, 01:13 PM   #5
Air is about 78% nitrogen, so I wouldn't worry about using air to bring the pressures up. In fact, I have raced cars for years, and we even quit using nitrogen. The thought is that pure nitrogen expands less with heat compared to air, therefore keeping tire pressures, and subsequently the circumference of the tire, from growing when heated. Others will claim, somewhat justifiably, that pure nitrogen in tires reduces oxidation on the inner wheel. The 282RK has aluminum rims so no advantage there. Finally, some of the oxygen in regular air will permeate the rubber over time causing a slight loss of pressure. We should be checking pressures often so no advantage for nitrogen there either.
Lee and Anne
Old 05-24-2016, 04:21 PM   #6
Happy Camper
I concur. Nitrogen is a gimmick if you are pulling a camper. Maybe there is a very slight advantage if you are racing, but pulling a camper it is negligible.
pressure, salem, tire
