Old 08-18-2016, 05:51 AM   #71
They Work Awesome!
Originally Posted by Teamfour View Post
Based on a post by Bama Rambler in another thread, I just ordered the following vents.
Venting Products / AC Vents / "Jet Stream" #8850 Fully Adjustable Large RV AC Ceiling Vent - DW Inc. Here is the original thread, post #9 Bama's Rambling Mods.
I will report back to say how they work.
These vents worked very well. You can actually leave in the existing ring. Just pop out the vent and install clip in the new. Done! At $6 each I bought all 5.
Thanks!
Now if I can just find out where that cable TV splitter is? I need to rework it so that I can send my DirecTV signal to all connections.
MIRAIDERFAN is offline   Reply With Quote
Old 08-23-2016, 11:10 AM   #72
Jimmy54
jimmy54's Avatar
Hi. Pulling OK with 2012 F150 EB with tow package, WDH and Reese dual cam sway control. Did a 6000km return cross country trip in 2015. Main issue was trailer sway in windy conditions as the 282RK is a big tailend heavy trailer. Sway control and upgrading tires to wider LT285/55R20 has helped a lot. My feeling is a F150 EB has adequate power but is just a bit light of a platform for a 35' TT. Preference would be to have a 3/4 ton diesel..but past my budget at the moment.
jimmy54 is offline   Reply With Quote
Old 08-23-2016, 11:26 AM   #73
Not recommended, you want the slide to move with the rest of the camper or you could bind it up.
Uncle Buck is offline   Reply With Quote
Old 08-23-2016, 11:31 AM   #74
Tom
Seachaser186's Avatar
Thanks, after do some more research that seems to be the consensus. It actually does make sense when you think about it. I will do the X-Chocks instead.
Seachaser186 is offline   Reply With Quote
Old 10-01-2016, 05:11 PM   #75
I purchased a 2017 282RK in April and got through the summer loving it. Will be winterizing in the next few weeks. Can anyone tell me where to access the water bypass...in bathroom under sink or bedroom under closet?
Rod
trailtracker is offline   Reply With Quote
Old 10-01-2016, 05:50 PM   #76
Closet. Remove dresser drawers
mguymon is offline   Reply With Quote
Old 10-05-2016, 09:53 PM   #77
Does the 282RK have an 80" long bed or a RV queen? Thanks!
MD DAVE is offline   Reply With Quote
Old 10-06-2016, 09:42 AM   #78
RV queen in our 2014 model.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2018: 24 nights camped
Teamfour is offline   Reply With Quote
Old 11-04-2016, 11:14 PM   #79
exposurecontrol
Make that a "short" Queen, which I think are 74". Just bought one a couple months ago. And even the short queen extends beyond the support board by a couple of inches; at least in ours.
2015 Salem Hemisphere
2013 Ford F150; Eco Boost; Super Crew,
Max Tow Pkg
exposurecontrol is offline   Reply With Quote
salem
