Thanks for the info, I'll give that a try.
On the previous question about the wall over the stove, it is made of some type of foam, very light and it seems as though it was not fastened correctly when it was first installed, as a lot of the screws were not in the tiny studs behind it. We've been laying it out in the driveway in the full sun with weight on it. It has flattened out almost completely. I will reinstall with some 1/8" paneling behind it to have more attachment points - should work out fine. Better than spending $600 to replace it.
