Old 07-14-2016, 10:32 PM   #1
burch42's Avatar
Salem hemisphere 356qb front landing gear
Hey everyone, we are at the camp ground and the front landing gear sounds like the motor is going to quit at any minute, any fixes or encounters with this?
Also landing gear switch will not work, but remote operates it fine. Any thoughts?
burch42 is offline   Reply With Quote
Old 07-15-2016, 05:25 PM   #2
Head Rambler
There's a fuse inline with the switch power, between the switch and battery, Try replacing it and see if the motor sounds better.
The remote power is a smaller wire that's ran a greater distance than the switch wires, so it will have a greater voltage drop.
Once you report back about how that turns out, we can work on the motor and/or gears.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 07-16-2016, 08:56 AM   #3
burch42's Avatar
thx for helping bama, i traced the wire from the plug through the front compartments, no inline fuse. The wire goes into the battery box area, two inline fuses there. Not sure if those are for the battery or not.
Old 07-16-2016, 12:57 PM   #4
bhersh's Avatar
There definitely should be an inline fuse at about the center above the front compartment. You have to pull it out from inside the plastic that is around the wires to protect them. I put a resettable fuse in mine. I have shown this fuse to several other 356qbq owners at campgrounds. Also, are you aware of the hidden fuse panel behind the wall in the pass thru storage compartment?
bhersh is offline   Reply With Quote
Old 07-16-2016, 01:45 PM   #5
Head Rambler
My landing gear fuse was hidden in the wire loom behind the battery also. Had to open up the loom to see it.
Gotta go campin!
Old 07-16-2016, 01:57 PM   #6
Kenny kustom's Avatar
Here you go. Click image for larger version
Name:	ImageUploadedByForest River Forums1468691815.338889.jpg
Ignore the mess. I'm still waiting on my breaker panel to show up.
Damn customs.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
Old 07-16-2016, 06:38 PM   #7
burch42's Avatar
thanks for the help, located the fuse, it was blown, replaced and landing gear working normally now. thanks for everyones help. Making me sleep better with working landing gear when we just bought this brand new two weeks ago, was a little worried!
Old 07-16-2016, 06:40 PM   #8
burch42's Avatar
now to get the light by the front compartment to work!
Old 07-17-2016, 03:31 PM   #9
You said out is working normally now. Do you mean that the manual switch that wasnt working before is working too?
MOODMAN is offline   Reply With Quote
Old 07-18-2016, 02:46 PM   #10
Head Rambler
Thanks for coming back and letting us know that you found and fixed the problem.
I guess you'll be carrying a few extra fuses with you, huh?
Gotta go campin!
salem
