Old 02-27-2014, 08:37 AM   #11
Chewie's Avatar
I don't know why it's a "lite" model. It's not that light at all. When I bought mine, I weighed it right from the dealer with no load, it was right at 11,500 ish empty. Loaded I'm probably 12,5-13k. Pin weight was right about 2k on the nose unloaded.
I used to have a really nice motorhome
2016 Jeep Wrangler Unlimited
Chewie is offline   Reply With Quote
Old 02-27-2014, 08:39 AM   #12
Camper Less Camping
Cajun Po-Boy's Avatar
Great real world weights for Fifth Wheel Joy to consider...
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 02-27-2014, 03:58 PM   #13
RV maniac's Avatar
I pull mine with an 08 ford f350 dually with 4:10 gears. It pulls with ease and I hardly know its behind me. I dont think u would have much trouble pulling this fifth wheel with a 3/4 ton or a single wheel axle unless u were in the mountains a lot. Only reason I got a dually is because my truck isn't my daily driver so I wanted a dually so I could pull anything.
Sent from my SAMSUNG-SGH-I337 using Forest River Forums mobile app
RV maniac is offline   Reply With Quote
Old 04-13-2014, 05:45 PM   #14
RV maniac's Avatar
Anybody know where the fuse or breaker is for the main control panel?!? Slides and awning buttons still wont work and I have looked everywhere!
Old 04-13-2014, 07:51 PM   #15
jdavis12373's Avatar
The dealer that demoed mine said all fuses were in breaker fuse box below frig
jdavis12373 is offline   Reply With Quote
Old 04-18-2014, 02:48 PM   #16
dj3spots's Avatar
Tow our 346qbud with GMC Denali 3500hd duramax diesel with Allison transmission, SRW standard bed. Tows like a dream! No probs. updated from Chevy Siverado 2500hd SRW standard bed. Wanted to make sure hills wouldn't be a problem.
dj3spots is offline   Reply With Quote
Old 04-28-2014, 03:39 PM   #17
dj3spots's Avatar
Help! Have no power to our landing gear in 5th wheel 346qbud Salem Hemisphere. Can't unhitch trailer from truck without it. We checked all GFI and reset. Checked and reset all circuit breakers in panel below fridge and checked inline breaker in battery compartment. Trailer is plugged in to house power and everything in trailer works except for landing gear. Anybody have any other ideas?
Old 04-28-2014, 03:58 PM   #18
dj3spots's Avatar
salem hemisphere 356qbq
Ok. Found it! And for any one interested the fuse is a 30 AMP and is located in the front compartment in the middle over the compartment door frame. Hope that makes sense to any who have to find it.
Old 04-28-2014, 05:21 PM   #19
dlhigdon's Avatar
I had the same issue with my 346QBUD but if you have a remote for the slides and landing gear, the remote will work. (Or it did for mine). I am still having an issue with my fuse blowing when I use the switch but no issue when I use the remote.
dlhigdon is offline   Reply With Quote
Old 06-03-2014, 10:59 PM   #20
EZLIfe's Avatar
Originally Posted by Fifth Wheel Joy View Post
What size of truck do you use to pull your salem hemisphere 356 qbq.? I am think of buy one don't know if truck is big enough. Any advice?
I pull mine with a '11 Ford F350 Dually Crew Cab 6.7 Turbo Diesel.
EZLIfe is offline   Reply With Quote
