Old 07-26-2016, 08:48 PM   #1
Cooperville's Avatar
Salem Hemisphere 368rlbh extremely loud a/c
We have whatever roof a/c that came stock on our unit. It seems to run extremely loud all the time when it is on. It's so loud that you can't even sit inside and have a conversation without yelling at each other. Is this normal? Any input would be greatly appreciated
Cooperville is offline   Reply With Quote
Old 07-27-2016, 07:49 AM   #2
Happy Camper
Tonylmiller's Avatar
That is not normal. If it is new, I would take it back to dealer and have them listen to it. You could also listen to others with a similar unit. It should not be that loud.
2015 Salem Cruise Lite 262BHXL
Towed with 2015 Chevy Silverado
Tonylmiller is offline   Reply With Quote
Old 07-27-2016, 07:53 AM   #3
Might be a silly question, but is the air dump open? I know ours are super loud with the dumps open.
Dwayne and Susan
Jiro and Phoebe-4 legged family members
Mike and Dana - Traveling buddies
2016 Ford F350 XLT 6.7 Powerstroke DRW 4X4
2016 Brookstone 395RL
dwayneb236 is online now   Reply With Quote
Old 07-27-2016, 08:50 AM   #4
Head Rambler
What brand is the thermostat? That will tell us what brand the A/C is.
There have been several complaints of the Coleman Mach 8 units being loud.
As dwayneb236 said, they're all kinda loud if you have the air dump open.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 07-27-2016, 10:16 AM   #5
It has a dometic digital thermostat. And I'm referring to using the ducts and not dump
Old 07-27-2016, 11:10 AM   #6
Tfort's Avatar
Yes they are loud. That is the biggest complaint I have with our AC unit. The airflow is just to loud.
2000 F250 CC 4x4 7.3L diesel
15 Salem Hemisphere Lite356QB
Tfort is offline   Reply With Quote
Old 07-27-2016, 12:35 PM   #7
Head Rambler
While the Dometic 15k units are loud, they shouldn't be as loud as you described.
Is it a constant drone, or does it sound like something out of balance?
Gotta go campin!
Old 07-27-2016, 12:42 PM   #8
Inside shroud
I would start by removing the inside shroud and watch the fan turn and see if it has a bent blade. With the inside shroud removed you will be able to tell if it is inside or outside. If the inside fan is not making the noise then you may have to climb on the roof and take the outside shroud off and have some one turn the a/c on and see if the noise is the outside fan. look also at the bolts holding the compressor to the unit.
Bob Vaughn is offline   Reply With Quote
Old 07-27-2016, 05:12 PM   #9
my coleman/mack 13.5 is loud as well. we can have a conversation though but it's louder than i would like.
danc is offline   Reply With Quote
Old 07-27-2016, 06:14 PM   #10
Our 15k is loud enough that you have to double the volume on the TV when the AC is on. Our old 13.5k AC was just a tad quieter.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2016: 38 nights camped
Teamfour is offline   Reply With Quote
salem
