10-22-2017, 12:38 PM
salem rkss water pump
hey everybody... Just bought our 2018 salem 27-rkss. Getting ready to tackle winterizing so I have been locating everything for sake of getting to know my rig (furnace access, hot water tank etc...). For the life of my I cannot find the water pump, or an access panel for it?! Ive tried tracing the waterlines, and turning the pump on and listening to locate,,,,, no luck. Any help?
Thank you in advance!
10-22-2017, 12:43 PM
Mine is under the kitchen sink, behind a small panel.
10-22-2017, 12:46 PM
do you mean the 2 angled false walls under the sink?
10-22-2017, 12:49 PM
Yes sir, mine is behind the left panel.
10-22-2017, 12:50 PM
Check under the sink right beside the furnace. There's a panel there that's screwed to the floor. The pump is behind that.
Gotta go campin!
10-22-2017, 12:53 PM
thanks guys! could see the furnace was there thru the louvers. didnt bother poping that false wall out to look.
10-23-2017, 01:02 PM
I removed both those panels
The one on the right is where the valves are for the hot water tank and you'll need to turn off *both* those valves. There is one you can kind of reach over the panel, but the second one is by the floor and (take if from me!) you will pump antifreeze into your water heater if you don't turn off both.
10-23-2017, 01:50 PM
X2. If not already equipped, you might want to take this opportunity to install a CAMCO 36543 Pump Winterization kit. Easy to install and will save you time and effort for the winterization process. About $18 at WALMART.
2016 Salem 27RKSS
10-27-2017, 07:01 PM
pump location update
ok,,,, got under the sink and removed panels.... not water pump, just the furnace on the right side.... any thoughts?
10-27-2017, 07:15 PM
Have you tried to turn the pump on (presuming you have water in the tank), and opening a faucet a little bit (or the outdoor shower) and listen for the pump to cycle on and off?
Oops, I see you already tried that. Sorry.
FWIW, mine is in the “basement” behind a wall.
Joe
Current: 2022 Keystone Cougar 26RBS
Past: 2020 Rockwood MiniLite 2205S
Past: 2018 Flagstaff MicroLite 21FBRS
Past: 2005 Flagstaff Classic 625D
TV: 2016 Ford F-150 3.5 EcoBoost
10-27-2017, 07:27 PM
If you can't locate it by sound, then you'll have use some dead-reckoning. The pumps in the RKSS models are very close to the proximity of the FW fill.
2016 Salem 27RKSS
10-31-2017, 12:34 PM
found it!,,, it was under the "end table" between the recliners! lol. thank you everyone for your help
10-31-2017, 01:01 PM
Are you saying on your Salem 27RKSS the pump was here? (see pic)
2016 Salem 27RKSS
10-31-2017, 01:21 PM
yes sir! go figure?
10-31-2017, 04:40 PM
That is where mine was also.
10-31-2017, 04:44 PM
where were you a week ago!!!!! LOL
10-31-2017, 09:09 PM
Looking for my water pump. LOL
11-01-2017, 07:33 AM
That's crazy. Is your fresh water tank right under there?
Gotta go campin!
11-01-2017, 07:50 PM
That’s strange, I have a 27rkss and the water pump is under the sink.
2017 Nissan Titan XD CC SV
2017 Salem 27RKSS
11-01-2017, 09:03 PM
Yes. The water tank is right below it. The fill line and vent run through the cabinet then through the floor.
I just bought this travel trailer in September. It is a 2018. Maybe they have moved the pump in this year.
