Old 04-14-2018, 09:53 AM   #1
Salem Villa 385FLBH beck bedroom TV backer boatd
I am new to RVs. This is a 2015 and I cannot get information on size or thickness of the board. I know it is above the rear door because of power and cable outlets. How long of a bolt? Nervous doing it till I get info. Thank you in advance.
Cudjoe is offline   Reply With Quote
Old 04-17-2018, 04:44 AM   #2
We do not have that specific model, however felt your frustration with the minimal effort that goes into explaining the tv walk mounting. I even asked during my orientation if they could point us to where to mount it and the guy basically said no. We found that the backer board has a stub (if you knock on the backer you should feel a more solid spot) and this is where we mounted the bracket. We used the screws that came with the bracket. Has held up so far but we also have a 26 inch tv that is fairly light. We bought an easy dismount system so we can take it off during travel.
HappilyLost is offline   Reply With Quote
Old 04-23-2018, 04:02 PM   #3
I had the dealership put a tv mount in the bedroom- it came with power and cable hookup
Carl Patterson is offline   Reply With Quote
bed, boat, roo, salem
