Old 09-30-2013, 05:43 PM   #11
Originally Posted by Ford Idaho View Post
I say dually for the more stable platform.
It is about 40 feet long.
I agree. I think the weights are going to be unimportant. It's needs something large for the stability.
Old 09-30-2013, 05:53 PM   #12
Ford Idaho's Avatar
Yes, you stop and think about it this TT is about as long as some semi trailers.
Old 09-30-2013, 06:08 PM   #13
wneise's Avatar
These types of trailers are primarily for the full timer who doesn't move around to much. Like say winters in the south and summers up north. It's more of a mobile home than it is your typical RV trailer. If you do want a good weekender with loads of space, look at a fifth wheel or motor coach.
wneise is offline   Reply With Quote
Old 09-30-2013, 06:18 PM   #14
cbauch
yes, this salem villa estate is not going to be moved alot.....staying in this park until next aug. and then will decide where we will go for the next year. thanks
cbauch is offline   Reply With Quote
Old 09-30-2013, 06:26 PM   #15
Ford Idaho's Avatar
Would renting a pickup be a possibility or do you want to own?
Old 09-30-2013, 06:31 PM   #16
cbauch
well for me renting would work fine, but my husband will be returning back from afganistan and he thinks he needs a truck......he will probably win this battle.......lol thanks for your imput, greatly appreciate it
Old 09-30-2013, 06:32 PM   #17
I doubt that you can rent a 1-ton (or 3/4) that it's approved to tow with.
Old 09-30-2013, 06:34 PM   #18
Ford Idaho's Avatar
Never stand between a man and his truck......
And Thank You both for your service.
Old 09-30-2013, 07:26 PM   #19
chiefly1's Avatar
I like the Dodge diesel 6.7 3500 one ton but Ford or Chevy have models that will work. The diesel has power to spare and will last forever, the engine brake and tow haul mode will get you up the mountain easily as well as down it safely without touching your brakes for the most part. So, I suggest you put those items on your must have list for whatever truck model you go with.
chiefly1 is offline   Reply With Quote
Old 07-01-2014, 08:11 AM   #20
Water Heater
does anyone know if the salem villa estate hot water heater is electric or propane? stupid book doesn't tell much.......and i am a women rv'ing alone right now......just want to make sure i don't run out of propane
cbauch,
I'm new here, first post. I just bought a '14 Villa Estate 394FKDS. My water heater is both electric and propane. The electric switch is located in the heater compartment on the heater itself.
Gary
tri5ford is offline   Reply With Quote
