Old 10-06-2013, 06:13 AM   #1
Salem27 DBud
When not hooked up to power , should my trailer battery run my radio , awning, pump, slide out?
Nograc is offline   Reply With Quote
Old 10-06-2013, 06:33 AM   #2
Ford Idaho's Avatar
As long as it is charged it should.
Those should all be 12 volts.
Old 10-06-2013, 08:55 AM   #3
Battery power
Thanks , if it's not working what it where should I check . My trailer is a 2013 model
Old 10-06-2013, 01:54 PM   #4
bikendan's Avatar
have you checked the battery's charge?
if you don't have a battery disconnect switch and it's not plugged into shore power, the trailer's parasitic power drains will empty a battery in just a few days.
Old 10-06-2013, 02:32 PM   #5
Denver, CO
garbonz's Avatar
Originally Posted by bikendan View Post
have you checked the battery's charge? if you don't have a battery disconnect switch and it's not plugged into shore power, the trailer's parasitic power drains will empty a battery in just a few days.
X2. You would benefit from using a voltmeter to see what condition your battery is in, and if it is about 12.5 volts or above, then all the things you mention should work,UNLESS the battery disconnect is off or a fuse is blown. You may need to trace the wiring a bit and see where the problem lies.
2017 Fuse 23T
