Originally Posted by surfdogg65
I have a salem hemisphere ultra lyte as wondering how many screens I need to prevent wasps mud daubers and other insects from making a nest.
you can make most if not all, from screen wire and a little caulking, .... on the fridge vent cover just cut a little over size, press into place and the edge wires will act like little barbs and hold forever against the plastic, .... with the water heater cover, cut the pieces to size, apply caulking as shown in pics, lay wire into the wet caulking(can hold in place with tape if necessary), when dry, can remove tape and will have a permanent fix, .... using these two methods, you can plug/cover just about any area you find that the daubers would want to go into, I've done this on three different trailers and not a single problem ever, .... not necessary to buy covers, ...
