Old 11-10-2014, 06:11 PM   #1
Shaking of trailer after leveling
We just returned from our second trip with our Salem RKSS27 and I have a question that may have been answered elsewhere and if so please be kind enough to point me in the right direction. After leveling the camper from side to side and front to back, we found that there was still quite a bit of movement. Thought it might be the chocks not set properly but they seemed to be seated under tires correctly. Any idea how to eliminate this movement. Even our small dogs could cause movement. Stablizing jacks were down.
Please help.
Sandy and Steve
Chooie, Baby, Grizzly, Sophie the 4 fur babies
2018 Rockwood 8301WS fiver
2003 Ford F-250 super duty diesel
Vinemont, AL
Triple SS is online now   Reply With Quote
Old 11-10-2014, 06:26 PM   #2
mark0224's Avatar
X chocks and once your set in place check your stabilizers I have to adjust ours once or twice a week.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 11-10-2014, 06:31 PM   #3
BillyBass's Avatar
Level it front to back first then left and right then put down the jacks firmly
2012 21' FR Micro Lite FBRS
2005 GMC Sierra 1500
2012 24 nites 2016 16 nites
2013 25 nites 2017 19 nites
2014 14 nites
2015 16 nites
BillyBass is offline   Reply With Quote
Old 11-10-2014, 06:32 PM   #4
davel1971's Avatar
x2 on the X chocks. Use 2 of them. If you want to haul enough wood blocks, like pieces of 6x6, using them under the stabilizers helps. The further you have to extend the stabilizers, the more they flex. You will never get all the movement out. Keep in mind its sitting on rubber tires that flex a bit.
David & Lynn
Old 11-10-2014, 07:35 PM   #5
Red face
Thanks everyone. I thought the X-chocks might help tremendously. Those that go under the tire just don't seem like they can do the job correctly or efficiently. Guess the next mod we make will be the x-chocks or perhaps scissor jack modified.
Sandy and Steve
Vinemont, AL
Old 11-10-2014, 07:46 PM   #6
davel1971's Avatar
its left right first, then front back. You cant level with stabilizers if that's what you are doing
David & Lynn
Old 11-10-2014, 07:49 PM   #7
Crusadernoob's Avatar
If you want to stabilize anything triangulation is the only way. Several aftermarket kits available, I made these myself for less than half the money.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 12
Crusadernoob is offline   Reply With Quote
Old 11-10-2014, 08:14 PM   #8
I use/install 2 Bal X chocks before I unhook, level the trailer front to back with the landing jacks, extend the rear jacks and axle jacks as far as possible without any wood blocking to get them as close to vertical as possible and tighten the front and rear homemade JT Strongarms. Both sets of stabilizers have reinforced legs and pipe supports. My trailer does not move. Also have a step support.
Old 11-10-2014, 09:08 PM   #9
Evereddie's Avatar
That's a solid point there, bar none.
Evereddie is offline   Reply With Quote
leveling, trailer
