Old 09-21-2015, 07:08 AM   #1
Should my awning be in further?
We went out in our unit for the first time this weekend.. When packing up i noticed our awning wasnt snug against the camper.. Maybe its in all the way but it just seems it should go in further... We cant get it past this point are we doing something wrong?? Or is this how it is?? This is a 195bh unit and there is a pole you hook on and turn to open and shut the awning. Click image for larger version
Name:	ImageUploadedByForest River Forums1442837298.623277.jpg
skissugar is offline   Reply With Quote
Old 09-21-2015, 07:12 AM   #2
wowzer's Avatar
Fairly common.
Jim and Sherri Brown
2013 Silverado 2500 6.6 DuraMax
2012 Sabre 34REQS6
wowzer is offline   Reply With Quote
Old 09-21-2015, 07:14 AM   #3
TURBS's Avatar
Does it seem like your awning arms are just a little off to the right or left of center?
If so your fabric has slid just a little bit in the roller tube one way or the other and caused it to roll up a little crooked.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
Old 09-21-2015, 09:44 AM   #4
DaveSchwartz's Avatar
On mine, the front arm (where the motor is) stays about 1/2" from what I'd consider totally retracted. However, I think that's OK because it means the spring tension has fully retracted the rear, unpowered end while the motor keeps the front end pretty well locked. Initially I looked for travel locks like the manual awning on my old TT but then came to the conclusion that power awnings don't have them.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 09-21-2015, 09:51 AM   #5
I would check the joints of your awning arms, something could be preventing them from closing completely, .......wires, junk, ect.
fella10 is online now   Reply With Quote
Old 09-21-2015, 11:49 AM   #6
We had the same problem which got worse with use. Dealer replaced awning, under warranty, because they said one side of canvas was 3/4" longer than the other. I thought it just needed adjustment. I got a new awning so my problem is solved. Report the problem to your dealer now and if it gets worse, continue to report the problem to the dealer and FR. Good luck.
Probwrm19 is offline   Reply With Quote
Old 09-21-2015, 12:58 PM   #7
I agree with Probwrm19. Mine is nice and snug with wall.
alimen is offline   Reply With Quote
Old 09-21-2015, 12:59 PM   #8
We had the same problem. Dealer said the awning was 1/2" to 3/4" 'out of square'. They replaced the whole thing and still have the same problem.
Just another reason Forest River is on my list of do not buy again. Too many warranty issues that ended up no better off than before.
jgriffin7 is offline   Reply With Quote
Old 09-21-2015, 01:45 PM   #9
Originally Posted by skissugar View Post
We went out in our unit for the first time this weekend.. When packing up i noticed our awning wasnt snug against the camper.. Maybe its in all the way but it just seems it should go in further... We cant get it past this point are we doing something wrong?? Or is this how it is?? This is a 195bh unit and there is a pole you hook on and turn to open and shut the awning. Attachment 89422
We have the same model and awning and ours fit similar to yours. The reel doesn't allow the roll to fit snug to the wall leaving a gap. As long as the support structure is snug, I wouldn't worry too much.
gfarmcafe is offline   Reply With Quote
Old 09-21-2015, 06:22 PM   #10
A32Deuce's Avatar
How is the awning a forrest river problem. They don't make them. They are provided by an outside contractor. same as Water heated, fridge, water pump, ETC.
A32Deuce is online now   Reply With Quote
awning
