Old 06-18-2019, 12:03 PM   #1
wifeytojosh's Avatar
Shower knob broke off
Our shower knob broke off and we are camping. If I turn on the pump so we can flush the toilet. Etc. Water shoots out from where the knob is supposed to be. Is there a way to turn off just the shower water? Is there a valve somewhere? Thanks
wifeytojosh is offline   Reply With Quote
Old 06-18-2019, 12:30 PM   #2
No separate shut off valve for the shower or sinks in a R/V.
You could easily go to Lowe's or Home Depot or any good plumbing store and buy a 'Shark-Bite" inline shut off and plumb it into the supply line. (typically PEX tubing)
With a 'Shark-Bite' type fitting, all that is required for installation is to cut the PEX tubing and push the ends of the line into the fitting.
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 06-18-2019, 01:44 PM   #3
If the husband was handy, that would be great but he isnít. I was just hoping there was a valve somewhere that I could shut off
Old 06-18-2019, 01:48 PM   #4
Is the wife handy?
gbaldwin is offline   Reply With Quote
Old 06-18-2019, 02:25 PM   #5
Well... the shower knob needs to be fixed anyway so if the hubby isn't handy, you may as well call a repair person right now.
A good mobile repair person will have you fixed up in a jiffy.
Old 06-18-2019, 02:34 PM   #6
If the husband was handy, that would be great but he isn’t. I was just hoping there was a valve somewhere that I could shut off
Show your hubby you are handy, this is an easy diy repair.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 06-19-2019, 09:36 PM   #7
The water feed line for the faucet is a screw-on fitting that should be accessible using the inspection port. If you remove the cold feed line to the faucet, you can screw a plastic plug into the fitting which will stop the water flow until you can get a replacement faucet. Any hardware store should have the plugs.
Phil
pmsherman is offline   Reply With Quote
show, shower
