Old 03-24-2015, 10:01 PM   #1
Slide out breaker????
New to forum and Salems. The wall switches for the slide outs our dead and I don't see it listed on the fuse box. No issue with the remote to bring in or out the slides. Is there another fuse or breaker I'm missing?
Cha-Chi is offline   Reply With Quote
Old 03-24-2015, 10:09 PM   #2
VinceU's Avatar
Yes due to higher amp capacity of slides and levelers, breakers or resettable fues are "in line" of the heavy wiring supplying those loads. Some have reset buttons, some are auto reset once supply power is removed. Normally these devices are located close to battery moumted on frame or in protective box.
Old 03-24-2015, 10:13 PM   #3
Thanks...I'll give that look see.
Old 05-18-2015, 05:16 PM   #4
Did you figure it out? Mine doing same thing
mikejjaci is offline   Reply With Quote
Old 05-18-2015, 05:27 PM   #5
wmtire's Avatar
Just spitballing here, but what remote do you have. I have been reading where some members who have certain remotes, that the remote overrides the wall switches. I know this has been happening to those who turn on their porch light with the remote...then the wall switch doesn't work, till they turn off the light with the remote again.
You might can read the instructions for the remote and see if there is some kind of manual override to the remote.
Like I said, just something to think about to see if that's also the case here.
http://www.forestriverforums.com/for...off-81717.html
2011 Flagstaff 831 RLBSS
Old 05-18-2015, 05:41 PM   #6
I have LCI remote. Fuse panel behind wood panel fuse 1 2 3 and 4 have power to them this is the panel that remote sends to. There's three fuses bellow them not marked with numbers that have no power to them
Old 05-18-2015, 06:33 PM   #7
Got it narrowed down its the supply board behind the wood panel. It's got some fuses that are too reset themselves after being tripped. They are not supplying power to switches. They're sending new board
Old 05-22-2015, 07:54 AM   #8
Thanks...mikejjaci...
checking that out...
Old 05-23-2015, 10:02 AM   #9
You have to find the panel that has no circuit breakers in it Just fuses. I think you'll find fuses in there that have no power. I jumped from white/blue that had power to white/blue that had no power. Manual slide buttons worked. I have hemisphere 300bh
Old 05-23-2015, 10:13 AM   #10
Traveling Two
jerryliving's Avatar
When my slideout would not operate, I found a fuse (in the fuse/breaker box) was blown. Simple fix this time.
jerryliving is offline   Reply With Quote
breaker, slide, slide out
